Calculating the moment of inertia of a rod as a point mass
In summary, the moment of inertia of a rod with consistent density rotating about its end is M(L^2)/3. However, if you treat the rod as a point mass and try to calculate this using mr^2, you get M(L/2)^2=M(L^2)/4. This is because the formula has a distance from the rotation axis squared in it. In order to accurately calculate the kinetic energy of a rotating object, both the rotational and translational components must be taken into account.
ItDoesn'tMatter
The moment of inertia of a rod with consistent density rotating about its end is M(L^2)/3. However, if you treat the rod as a point mass and try to calculate this using mr^2, you get M(L/2)^2=M(L^2)/4. Why doesn't this work?
Because the formula has a distance from the rotation axis squared in it ! That's why.
Simple case to try out: two point masses at the ends of a massless stick.
The moment of inertia is generally used to calculate the kinetic energy of a rotating object.
The kinetic energy of your rod -- or any rigid body -- is composed of one part having to do with the rotation of the body about some axis fixed in the body and one part having to do with the translational motion of a point on that axis. If the point with respect to which the rotation is defined is stationary, then translational kinetic energy does not factor into the calculation; if the point is moving then translational kinetic energy does factor into the calculation.
There are two ways of calculating the kinetic energy in your problem. One is to find the moment of inertia about the end point and treat the motion as a pure rotation (i.e. no translational part). This gives, as you say, $$T=\frac{1}{2}I\omega ^2 = \frac{ml^2}{6}\omega ^2.$$
The other way of doing it is to calculate the moment of inertia about the center of mass, which is moving, so that we must add in a translational part. The moment of inertia about the center of mass is ##\frac{1}{12}ml^2## so we have $$T=\frac{1}{2}I\omega^2 + \frac{1}{2} m v^2 = \frac{1}{24}ml^2\omega^2 + \frac{1}{2}m\bigg(\frac{l\omega}{2}\bigg)^2 = \frac{ml^2}{6}\omega^2.$$
Clearly they are the same. So what you are doing when you get the wrong answer is essentially you are calculating the energy due to translation of the center of mass and ignoring the fact that there is also a rotation about the center of mass.
Related to Calculating the moment of inertia of a rod as a point mass
What is the formula for calculating the moment of inertia of a rod as a point mass?
The formula for calculating the moment of inertia of a rod as a point mass is I = ml²/12, where m is the mass of the rod and l is the length of the rod.
How do you calculate the moment of inertia of a rod if it is not a point mass?
If the rod is not a point mass, you will need to use the parallel axis theorem to calculate the moment of inertia. The formula is I = Icm + md², where Icm is the moment of inertia about the center of mass and d is the distance between the center of mass and the axis of rotation.
What is the difference between moment of inertia and moment of force?
Moment of inertia and moment of force are two different physical quantities. Moment of inertia is a measure of an object's resistance to rotational motion, while moment of force is a measure of the tendency of a force to cause an object to rotate about a specific point.
Can the moment of inertia of a rod be negative?
No, the moment of inertia cannot be negative. It is always a positive value as it is a measure of an object's resistance to rotational motion.
What factors affect the moment of inertia of a rod?
The moment of inertia of a rod is affected by its mass, length, and distribution of mass along the rod. A longer or more massive rod will have a higher moment of inertia, while a more concentrated mass distribution will result in a lower moment of inertia.
  • Mechanics
  • Mechanics
