Calculating the Speed of a Sand Pile's Height Increase
superjen
Sand is falling into a cone whose height is always 1/2 the diameter of the base. If the sand is falling at a rate of 1/2 cubic meters per min. How fast is the height increasin when the pile is 3 meters high?
so far I've drawn my diagram and got this far.
Given:
h = 1/2 the base
dv/dt = +1/2m3/min
Needs:
dh/dt
the equation i was going to use is
V = 1/12pih3
then i get
dv/dt = (1/2pi)(3h2)dh/dt
i don't know how to get the h?
any help?
You're asked to find dh/dt when the height is 3 meters...so h=3:wink:
But there is a problem with your starting equation V = (1/12)pih3...If the height is always half the diameter, then r=4h not h/4
ok, that was stupid of me,
i don't even know why i was having trouble with that now >.<
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
