B Calculating the torque needed to rotate a drum
To calculate the torque needed to rotate a drum, key factors include the drum's weight, radius, and whether it experiences friction or acceleration. In this scenario, with a static load and no friction, the required torque would be zero. However, if the drum is performing work, such as tumbling materials, the torque calculation becomes more complex. The placement of the motor and the orientation of the belt also impact the design considerations. Ultimately, without additional details on these variables, a precise torque calculation cannot be made.
jonas_biermann
Imagine this: You have a drum with a radius of 12cm, around that drum is a toothed belt which is connected to a motor. The drum weighs 10kg
The motor should be placed under the drum
How would I calculate the amount of torque needed to rotate the drum
I don't have any idea how to calculate this but it would be nice if somebody could answer :)
This question is unanswerable with the information you've provided. It really matters a lot if the rotation is accelerating, and if so what the mass moment of inertia around the axis is, if the drum is doing any work (like if there is maybe stones inside it to be fractured or whatever), if there is friction, etc. etc.
The accelaration is static. There are plants in the drum but the center of mass is in the middle of the drum. For my example friction can be neglected.
If there is no friction and no acceleration, and the drum does no other type of work, then the torque is zero
How can the motor be under the drum if there is a horizontal belt connecting them? Or are they both horizontal and the belt is vertical, and you are tumbling something inside the drum?
What about the motor bearing friction, and the losses in the belt drive?
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
