Calculating the Total Sum of 5-Digit Numbers with and without Repetition
  • MHB
  • Thread starter juantheron
  • Tags
    Sum
In summary, the Total Sum of $5$ Digit no. which can be formed with the Digit $0,1,2,3,4,5,6,7$ is $21288960$.
juantheron
247
The Total Sum of $5$ Digit no. which can be formed with the Digit $0,1,2,3,4,5,6,7$.
[a] when repetition of digit is allowed
when repetition of digit is not allowed
Hi Jacks, :)
I'll answer the first part of your question. By the same logic you should be able to complete the second part.
Note that we cannot have zero as the last digit (counting digits from right to left) of the number. Hence for the last digit we have only 7 possibilities. Suppose if we fix 0 as the first digit then we have \(7 \times 8^3=3584\) numbers, and the sum of the first digits of all those numbers will add up to \(0\times 7\times 8^3=0\). Similarly if we take 1 as the fist digit the sum of all those numbers will add up to \(1\times 7\times 8^3=3584\). Generally, if we add up all the ones places of the numbers the sum would be,
\[3584\times (0+1+2+3+4+5+6+7)\]
Similarly if we add up all the tenth places of the numbers the sum would be,
\[3584\times (0+10+20+30+40+50+60+70)=35840\times (0+1+2+3+4+5+6+7)\]
Continuing with this reasoning we get the total sum as,
\[(3584+35840+358400+358400+8^4)\times (0+1+2+3+4+5+6+7)=21288960\]
Thanks Sudhakara.My Try for (II)First we will form a $5$ Digit no. using $\{0,1,2,3,4,5,6,7\}$
(It also include a $4$ Digit no. bcz $0$ at extreme left. )
So Total no.,s e $ \displaystyle = \binom{8}{5} \times 5! = \frac{8!}{3!}$Each digit has an equal chance of being selected into any particular possition.
So, for example, the digit 2 will occupy the units position in $\displaystyle \frac{1}{8}$ of the arrangements.
So The sum of the arrangement each of $5$ position is $\displaystyle = \frac{1}{8}\left(0+1+2+3+4+5+6+7\right)\cdot \frac{8!}{3!}$
So Total Sum of $5$ Digit no. including $0$ at Thousant place is $\displaystyle = \frac{1}{8}\left(0+1+2+3+4+5+6+7\right)\cdot \frac{8!}{3!}\cdot (1111)$
Now We Will Calculate Sum of $4$ Digit no. Using $1,2,3,4,5,6,7$
Using same Idea We Get $\displaystyle = \frac{1}{7}.\frac{7!}{3!}\cdot \left(1+2+3+4+5+6+7\right)\cdot (1111)$
So Total Sum of $5$ Digit no. is $\displaystyle = \frac{1}{8}\left(0+1+2+3+4+5+6+7\right)\cdot \frac{8!}{3!}\cdot (1111) - \frac{1}{7}.\frac{7!}{3!}\cdot \left(1+2+3+4+5+6+7\right)\cdot (1111)$
- - - Updated - - -
FAQ: Calculating the Total Sum of 5-Digit Numbers with and without Repetition
What is the formula for finding the sum of a 5 digit number?
The formula for finding the sum of a 5 digit number is (a + b + c + d + e), where a, b, c, d, and e are the individual digits of the number.
Can you explain the concept of "carrying over" in the sum of a 5 digit number?
When adding two numbers, if the sum is greater than 9, the extra digit is "carried over" to the next place value. In the sum of a 5 digit number, if the sum of the ones place is greater than 9, the extra digit is carried over to the tens place, and so on.
How do you find the sum of a large 5 digit number quickly?
One way to find the sum of a large 5 digit number quickly is to use the distributive property. Break the number into smaller parts, such as thousands, hundreds, tens, and ones, and add them individually before adding all the sums together.
What are some real-world applications of finding the sum of a 5 digit number?
Finding the sum of a 5 digit number can be useful in various fields such as finance, statistics, and computer science. For example, calculating the total sales of a company, finding the average temperature over a week, or performing digital image processing.
Can you find the sum of a 5 digit number if the digits are not in a consecutive order?
Yes, the digits of a 5 digit number can be in any order and the sum will remain the same. This is because addition is a commutative operation, meaning the order of the numbers being added does not affect the result.
