Calculating Time and Distance for a Tram with Sinusoidal Velocity
The velocity of the tram is modeled by the equation v = 16sin(pi(t)/30) m/s, indicating that it oscillates as it travels. To find the time lapse between stops, the maximum velocity, and the distance traveled, one must determine when the velocity equals zero, as this indicates the tram's stops. The displacement can be calculated by integrating the velocity function over the relevant time interval. The integral requires defining the start and end times based on when the tram begins and stops moving. Understanding these relationships is crucial for solving the problem accurately.
ashclouded
The velocity of a tram traveling on a straight line between two stops is given by:
the distance traveled between stops
the maximum velocity of the tram and when it occurs
Displacement = x
Velocity = dx/dt
acceleration = dv/dt
I don't have a clue how to start it
Hey,
You would want to know at what time the tram stopped. At what value would you equate v if you want to know when it stopped after it started? Since this equation is a sine wave, you know that the velocity oscillates. What is the relationship between displacement and velocity according to calculus. You were given an equation for velocity, then how do you find displacement from there?
Displacement is the antiderivative of velocity so I can find the intergral of the given equation, I'm still not sure about the first question on finding the time it stopped
Since you want to find the displacement, you want to find the integral of the velocity expression. I understand that's what you already know. The integral has two defining values when calculating it: beginning (start) and the end (finish). The time velocity begins and the time velocity stops. At what speed does v equal when velocity suddenly stops. Put it another way, when an object stops, what does the value v equate to. This should be the value of the upper value of the integral.
I'm not sure if I explained it clearly.
v will = 0 at rest, but if the initial velocity is also 0 and final velocity is 0 also then I don't know how I can get the desired answer if that made sense
The distance is just the integral from start to finish. When you find the value of the time when v = 0, then you can calculate the integral between the start and when the tram stops.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
