Calculating Tm of PCR Product for RT-qPCR Melting Curve
  • Thread starter Thread starter mountain
    Product
To calculate the melting temperature (Tm) of a PCR product, it's important to recognize that PCR products are double-stranded DNA, while primers are single-stranded. The Tm of a PCR product can be estimated using similar principles as for primers, but adjustments must be made to account for the double-stranded nature. Online calculators can assist in this process, as they typically consider the length of the nucleic acid and other factors. When running a melting curve in RT-qPCR, calculating the Tm for the PCR product as if it were single-stranded can provide useful insights, especially for confirming product specificity.
mountain
I know how to calculate Tm of a primer but what about of a PCR product?
I want to run the melting curve in RT-qPCR to test for the products and i want to know Tm of the products to be sure.
Thanks.
Biology news on Phys.org
Why not use the same calculation as the Tm of a primer? A good calculator should takes into account the length of the nucleic acid. How do you calculate it now?
Here's an online calculator http://biotools.idtdna.com/analyzer/
The difference between a primer and a PCR product is that the PCR product is a double stranded DNA while the primer is just a singel strand. So should i calculate Tm for the PCR product like as it is a single strand?
Although you calculate Tm with a single strand for primer, it is use to separate your double stranded DNA.
So for your PCR product calculate with the single stranded DNA sequence.
I've been reading a bunch of articles in this month's Scientific American on Alzheimer's and ran across this article in a web feed that I subscribe to. The SA articles that I've read so far have touched on issues with the blood-brain barrier but this appears to be a novel approach to the problem - fix the exit ramp and the brain clears out the plaques. https://www.sciencealert.com/new-alzheimers-treatment-clears-plaques-from-brains-of-mice-within-hours The original paper: Rapid amyloid-β...
