Calculating Upward Support Force on a Rigid Beam
  • Thread starter Thread starter guru
    Beam Force
A 3.0-meter rigid beam with a mass of 100 kg is supported at both ends, with an 80 kg student positioned 2.0 meters from one support. The weight of the student is calculated to be 784N, and the weight of the beam is 980N. The upward force exerted by support 1 was initially miscalculated, as the moments caused by both the student and the beam were not properly considered. The correct calculation involves using the equation (2x784) + (1.5x980) = 3xF, leading to the upward force at support 1 being determined as 751.33N after accounting for the total downward forces. Acknowledgment of the beam's weight was crucial for arriving at the accurate force exerted by the supports.
guru
A 3.0-m-long rigid beam with a mass of 100 kg is supported at each end. A
80 kg student stands 2.0 m from support 1. How much upward force does support 1 exert on the beam?
I first found the weight of the student to be 784N.
so 784N*2cm =F*3cm
F= 522.67N
is this right?
No, its not. I think you forgot to take the moment caused by the weight of the beam.
I think this is how it should be done:
(2x784)+(1.5x980) = 3xF
This gives us the value of F(Force on the other support)=1012.67N
Substracting this value from the total downward force(784N+980N) we get the upward force exerted by the support1 be 751.33N
Yes, I forgot to consider the weight of the beam.
Thanks.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
