Calculating velocity of an object after very long time
  • Thread starter Thread starter Nikhil faraday
    Time Velocity
The problem involves calculating the velocity of a particle with acceleration defined as a = g - Kv, where g and K are constants. Starting from rest, the question seeks the velocity after a long time. The discussion raises concerns about whether the velocity will increase indefinitely or stabilize at a constant value. It is suggested that if the velocity approaches a constant, the acceleration would approach zero. The potential answers for the final velocity include g/K, 2g/K, and g/2K.
Nikhil faraday
Acceleration 'a' of a particle moving in a straight line as a function of velocity 'v' is given as a = g-Kv where 'g' and 'K' are constans . if the object starts from rest then velocity of the object after very long time is ?[/B]
a= v dv/dx
I don't know exactly what equation should be used
Not getting any idea to solve it due to the problem statement which is given as to "calculate the velocity of the object after very long time".
The options given are:
1) g/k
2) 2g/k
3) g/2k
[/B]
Will the velocity increase without limit? What would happen to the acceleration if it did?
If the velocity tends to some constant value, what does the acceleration do?
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
