Calculating Volume of Weather Balloon to Lift 4220kg Package
  • Thread starter Thread starter Corky
    Balloon Weather
To lift a 4220kg package, a weather balloon weighing 507kg must have a specific volume filled with helium at standard temperature and pressure (STP). The buoyant force must equal the combined weight of the balloon, package, and helium. The calculations indicate that a volume of approximately 4260 m^3 is required. The buoyant force is derived from the equation balancing the weights and the volume of helium. Understanding the densities of air and helium is crucial for accurate calculations.
Corky
A 507kg weather balloon is designed to lift a 4220kg package. What volume should the balloon have after being filled with helium at STP in order that the total load can be lifted.
I have no idea how to start this problem...
This is a bouyancy problem. Get to the Archemedes section of your text. Find densities of air and helium.
The bouyant force balances the total weight of the balloon , tha package and the helium gas.
I get a volume of 4260 m^3.
All right, so:
W(balloon) + W(package) W(helium) = F(bouyant)
4973.67 + 41398.2 + [0.179 * volume * 9.81](heluim) = F
= 1.29 * volume * 9.81
But what do I put if for volume..??
got it thanks
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
