Calculating Wave Speed and Wavelength for a Vibrating String
To calculate the wave speed and wavelength of a vibrating string with a mass per length of 500 g/m and a tension of 400 N, the formula v = √(T/(m/L)) is used. The user initially miscalculated the wave speed due to unit errors, as they used grams instead of kilograms in their calculations. The correct approach requires converting the mass to kilograms, ensuring proper unit cancellation. After correcting the units, the wave speed can be accurately determined. Understanding these concepts is crucial for solving similar physics problems effectively.
ddsMom
A long string with a mass/length of 500g/m is placed under a tension of 400N. The string is then vibrated up and down with a period of .425sec.
What is the wave speed?
What is the wavelength of the resulting wave?
I have no idea where to beginI would really like to learn this. It's been 20+ years since I have taken a Physics course.
Thank you!
I have no idea where to begin other than this formula:
v=λ/T
Thank you!
what resource are you using? (textbook, on-line notes, ??)
...(here are some very brief notes : http://www.science.marshall.edu/foltzc/211t9.htm )
generally to get a speed, you square root a (Force term divided by an inertia density).
tweak the density so that the units come out right for speed.
sqrt[T/(m/L)].
Likes 1 person
I did use v=sqrt[T/(m/L)]
so I got v=sqrt[400N/(500g/m)] = .029
Am I on the right track?
Changed my g to kg. Thank you so so much for confirming.
No. You have made error in calculating square root.
Likes 1 person
right track, but off by a UNITS error ... recall that Newton is composed of kilo-gram, not gram. (N=kg m/s²)
Always include the units that any numerical value multiplies; kg should cancel inside the sqrt.
Likes 1 person
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
