Chemistry Calculation Error: 0.19 = (0.14 - 0.13) - 0.06/2*log(1/(0.1*[Pb2+]))
  • Thread starter Thread starter hidemi
    Calculation Error
The calculation presented indicates that 0.19 equals (0.14 - 0.13) minus 0.06 divided by 2 times the logarithm of the inverse of (0.1 times [Pb2+]), leading to a calculated [Pb2+] of 4.6*10^6. Participants in the discussion identify a potential error in the calculation and express uncertainty about whether the mistake lies with the questioner or the provided data. There is a call for clarification on the cell reaction equation and the correct expression for K. The conversation highlights discrepancies in the calculations and encourages further examination of the problem. Accurate calculations are crucial for understanding the chemical equilibrium involving lead ions.
hidemi
The voltaic cell, Pb(s) Pb2+, Na2SO4(0.1M),PbSO4(s) // Sn2+(1M) Sn(s), generates voltage of 0.19V. The standard reduction potentials for Pb2+ and Sn2+ are – 0.13V and -0.14V, respectively.
(A)What is the concentration of Pb2+ in the anode compartment?
(B)Calculate the Ksp for PbSO4
Ans: (A)1.75x10-7M (B)1.75*10-8
E1 = E2 - 0.06/n*log(K)
My calculation:
(A) 0.19 = (0.14 - 0.13) - 0.06/2*log(1/(0.1*[Pb2+]) => [Pb2+] = 4.6*10^6
I wonder where I did wrong. Thanks!
Write out the equation for the cell reaction. Then write out the correct expression for K.
There appears to be a mistake in your calculation. However, I wonder if the questioner made the same mistake, or there is a mistake in the given data, because I disagree with the given answer.
Thank you for pointing out the mistake and I think I got a more reasonable answer.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
