Calculation of % component of resultant force
The discussion centers on calculating the percentage contributions of vector components to a resultant force. A resultant force of approximately 7N is derived from components of 3N, 4N, and 5N in the x, y, and z directions, respectively. The initial method of calculating percentages (5/7*100) yields values that exceed 100% when summed, indicating a misunderstanding of vector representation. It is clarified that percentages should be based on the squares of the components, leading to a correct representation where the total equals 100%. Ultimately, while one can describe vector components in percentage terms, the practical application of such percentages is limited.
soundproof
Hi everyone,
This appears to be a trivial question but I'm uncertain to the correct answer.
If I have forces of 3N, 4N and 5N in the x,y and z directions respectively. The resultant force will be the square root of these components squared ≈ 7N. If I want to describe any of the components as a % of the resultant force, how is this done?
I have seen in a journal paper that from my example the z-component of the force is calculated as 71.4% (5/7*100) of the resultant force, while the y-component was 57% of the resultant force. The addition of these percentages is greater than 100% so this cannot be true.
If I calculate the z-component as a % of the resultant force by dividing the squares of each number (5^2/7^2*100), then the addition of each % component sums up to be 100% (x - 18%, y - 32%,z - 51%). Is this method correct and if so can someone explain to me why it is necessary to square both vectors.
Thank you
Mathematics news on Phys.org
welcome to pf!
hi soundproof! welcome to pf! :smile:
this seems a pretty crazy idea to me
what would be the point? :confused:
anyway … you have |F| ~ 7, F.i = 3, F.j = 4, F.k = 5
32 + 42 + 52 ~ 72,
so of course (3/7)2 + (4/7)2 + (5/7)2 ~ 1 :wink:
soundproof said:
Hi everyone,
the sum of
The magnitude of the resultant force will be \sqrt{9+ 16+ 25}= \sqrt{50}= 5\sqrt{2} which is, yes, about 7.
So the x component is about 3/7= 0.429... or about 43% of the whole, the y component is about 4/7= 0.571... or about 57% of the whole, and the z component is about 5/7= 0.714 or about 71% of the whole.
You are reading a journal paper and cannot do basic arithmetic?? Of course, the percentages do not add to 100%, they are not numbers, they are vector components:
\sqrt{(.42)^2+(.57)^2+(.71)^2}= 1 instead.
Thank you
You cannot find a "percentage" of a vector because a vector is not a number. What you are doing is finding percentages of lengths of vectors. And the length of a vector is, by definition, the square root of the squares of the components.
Thank you for your replies.
Just to clarify regarding this statement -
So, it is not correct/possible to describe a vector in terms of % contributions of x, y and z components? And this is because I am trying to relate a length/scalar to a vector?
you can describe anything you like, but if you want the percentages to add to 100, it's difficult to see how it could be of any practical applicaton
(we can define the efficiency of a force …
if we want something to move horizontally, but we pull on it with a rope at an angle, then the efficiency would be the horizontal component divided by the whole force)​
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
