Calculation of RMS Voltage and Current
The discussion centers on calculating the RMS voltage and current for a theoretical circuit resembling an on-off switch with a 50% duty cycle. The voltage input is a constant 5V, while the current is 1A when the switch is ON and 0A when OFF. It is clarified that the RMS voltage across the resistor is not 5V but rather 5/√2 due to the nature of the waveform. The concept of Prms is discussed, concluding that there is no specific term for Prms; average power should be used instead. The integration of voltage and current over time is emphasized as a method to determine average power rather than relying on RMS calculations for non-sinusoidal waveforms.
vinayakbhat82
I've a theoretical circuit that resembles an on-off switch with a duty cycle of 50%. The voltage input to the circuit is a constant 5v. The current drawn from the source is 1A when switch is ON and 0A when OFF. What is the Vrms and Irms?
From what I know:
Vrms for constant 5v is 5v.
Irms for above current (square wave with 50% duty cycle) would be I/√2 = 1/√2.
This imples P=Vrms*Irms = 5/√2
However, if we separately do some calculations for power, it would be like 5*1*0.5 (V*I*duty chle) = 5/2.
Can this discrepancy be explained please? Please let me know what am I missing.
From what I know:
Prms = Vrms * Irms is only valid for a purely resistive load.
If you have a battery, a switch and a resistor in series, you can consider V and I across the resistor, and V won't be constant, so Vrms isn't 5V.
You can also consider V and I across the resistor and switch, and then Prms = Vrms * Irms
isn't valid and you have to do an integral of V(t)*I(t) over one cycle.
Hey willem2,
Thanks for the reply.
Yes, I did have that idea earlier, but I was trying to answer the following: If I've a blackbox that has the circuit you mentioned i.e. switch and a resistor with no access to internal nodes and I need to have a DC equivalent of the original source that delivers the same power, how would I arrive at the numbers if I was provided with the voltage and current waveforms at the boundary. By reverse engineering, we may say that Vrms needs to be 5/√2 in this case, however, I wanted to understand the rationale behind doing so.
I completely agree to your point that the rms voltage across the resistor would not be 5v, but would rather be 5/√2.
Is there a term called Prms or is it just P/ If so, please help me understand. Also I believe, integrating V*I over time will give you Energy.
There's no Prms, just average power.
The integral indeed gives the energy used in one period, so you'll have to divide by the length of the period to get the average power.
This is valid only for a sine wave. ie the I/√2
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
