roldy
- 237
- 2
I posted I question in regards to shock angles on this very same problem earlier but now I have a new problem. I need to calculate the heat rate required in the combuster in order to ensure that the vehicle will cruise (delta z=0). I also need to find the mass flow rate of the fuel. h for the fuel is 1.2*108 J/kg.
Along with this, I need to find the area of the wing required to ensure constant altitude.
Attached is a crappy drawing of the hypersonic vehicle.
I have found all the forces for C, D, E, and for the wing I found the forces F and G in terms of the area.
The x forces resulting from the pressures on the different surfaces would hinder the movement of the vehicle. Thus they are the drag forces.
The y forces are the lift forces. And to maintain a constant altitude they must equal the weight of the vehicle.
Solving the y forces equation for area of wing( this term was included in the top and bottom forces of the wing...F=P/Area), I got a value of about 1.002 m^2
Plugging into the x forces for area, I got the thrust to be 19915.11 N
One thing that I'm not positive on is point e. How do I go about computing values for Mach, Pressure, Temperature, Total Pressure, Total Temperature, and Velocity if I can't get from ce to e due to lack of data (none) at ce?
So now I believe I can solve for the mass flow rate of the fuel and the heat rate required but I am not sure how to arrive at this point. I believe it involves the conservation of energy and conservation of mass.
mdot1+mdotfuel=mdot2
Qdot -Wdot +mdot1(h1+1/2U12)=mdot2(h2+1/2U22)
There is no work being done. Substitution for mdot2 and simplifying yields:
Qdot +1/2mdot1h1(U12-U22)=mdotfuel(h2+1/2U22)
This seems right but for some reason I believe I missed something here. There is no hfuel.
My professor pointed out to me that the prerequisite course for this class dealt with this kind of stuff albeit on a easier level. However, I did not take that course because I came from another university. The course there didn't cover much of this, just theory. So I am at a bit of a disadvantage. Sorry for the long post and crappy drawing. I really want to understand this (being that I spent 9 hours studying on the internet and solving for the various items). Any help would be awesome.
