Calculus, Analytical demonstration
araveugnitsug
Demonstrate Analytically:
If \lim_{x\to a}f(x)=L and L<0, there exists a δ>0 so that x\inDom(f), 0<|x-a|<δ \Rightarrow f(x)<0
2. The attempt at a solution
I start identifying what I want to demonstrate and what are my assumptions.
I'm aware I have to reach f(x)<0 from the fact that L<0 and using the definition of a limit, the x belonging to the domain is there so that it also covers the cases were if not stated, one could get a limit that does not exist due.
So I have:
0<|x-a|<δ and 0<|f(x)-L|<ε
and I suspect the way is not in the delta part but working with 0<|f(x)-L|<ε, but because epsilon is in relation to delta it never banish, meaning I would have to work with the other part.
0<|f(x)-L|
Because L<0 is part of the hypothesis
L<|f(x)-L|+L
L-|f(x)-L|<L
Triangle Inequality
L-|f(x)|-|L|<L
L-|f(x)|-(-L)<L
L-|f(x)|+L<L
L-|f(x)|<0
-|f(x)|<-L
L<-f(x)<-L
-L>f(x)>L
And I don't know where else to go to get the f(x)<0 form, I simply have no way to get rid of the L in the process without being left with an absolute value on f(x).
Using the defintion of limit, take \epsilon to be any number less than L.
It works wonderfully and makes it two simple steps. Thanks.
Though I'm inclined to ask; is this something that can always be done, correlating epsilon with the actual limit?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
