Calculus III Problem: find smallest angle
lizbeth
Find the smallest angle between 3x-2y-4z = 5 and {x = 1 + 2t, y = 3 + 4t, z = 5 + 6t}.
3x-2y-4z=5 is a plane, the other 3 equations constitute a line.
My understanding is that the angle between a plane and a line can be found by using the direction vector of the line and the normal vector of the plane, and applying the dot product formula,
n . v = |n||v|cos Θ.
Doing this, I get that theta is the inverse cosine of -29 / (square root of 29 * square root of 56), which comes out to 130.18 degrees. Since the smallest angle would be the acute angle, I subtracted this from 180 and got 49.82 degrees.
Professor says this is the wrong answer. Can anyone help steer me in the right direction?
You should look to the details of your working - could be as simple as an arithmetic mistake.
Note: if n is the normal vector to the plane, and v is the vector pointing along the line, then arccos(n.v/|n||v|) gives the angle between n and v, not between v and the plane.
Thanks, Simon. I have checked the arithmetic of n . v and also |n| and |v|, and those are correct. The inverse cosine of course I have to rely on my calculator for. :)
I think what you're saying is that since the angle that results here is the angle between n and v, that the angle I found by subtracting from 180 is still the angle between n and v, just on the other "side" of the plane, and that this further needs to be subtracted from 90 to find the actual angle -- is that right??
Well done - you should be able to verify this by a sketch.
Likes 1 person
Great! Thank you!
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
