MHB Calendar Trick: Uncover the Secret!
  • Thread starter Thread starter soroban
The discussion centers on a mathematical trick involving a 4-by-4 array of numbers from an old calendar. A volunteer selects a month and marks a square around a 4-by-4 section. They then follow a series of steps to circle numbers and cross out their respective rows and columns, ultimately leading to a total sum of the four circled numbers. The key to the trick lies in the mathematical structure of the array, where the total can be calculated as 4 times the upper-left number plus a constant, specifically 42, plus additional contributions from the column positions. This results in a predictable total of 4 times a specific number, showcasing the underlying arithmetic principles at play. The discussion highlights how the selection method guarantees that the sum of the chosen numbers relates directly to the numbers on the perimeter of the array, reinforcing the reliability of the trick.
soroban
. . . . . . . Calendar TrickGive your volunteer an old calendar and a marker.
Have him/her select any month.
On that month, draw a square around
. . any 4-by-4 array of numbers.
You turn your back and instruct him/her:
1. Circle any number in the square.
. . X-out all numbers in its row and column.
2. Circle any remaining number in the square.
3. Circle any remaining number in the square.
4. Circle the remaining number in the square.
5. Add the four numbers.Without turning back, you announce the total.
Before turning away, note the smallest number
in the square, x, in the upper-left.
Add 12 and multiply by 4.
The total is 4(x+12).Alternate method:
Add the smallest and largest numbers,
and multiply by 2.
Can you explain why this works?
As long as you know the upper-left hand number ($x$), we know we have one from each row, so that the number is at least:
$x + (x+7) + (x+14) + (x + 21) = 4x + 42$.
By our method of choice, we have have exactly one number from each column, as well, so the number in the first column contributes nothing additional to our minimum sum, the number from column 2 contributes an additional 1, the number from column 3 contributes an additional 2, and the number from the last column contributes an additional 3 (since these number are either:
$x,x+1,x+2,x+3$
$x+7,(x+7)+1,(x+7)+2,(x+7)+3$
$x+14,(x+14)+1,(x+14)+2,(x+14)+3$
$x+21,(x+21)+1,(x+21)+2,(x+21)+3$
respectively).
Thus we have $4x + 42 + 1 + 2 + 3 = 4(x+12)$ as our total.
Well done, Deveno!I thought I would explain the result of the instructions.
Consider the followng addition table:
. . \begin{array}{c|cccc|}<br /> <br /> &amp; 0 &amp; 1 &amp; 2 &amp; 3 \\ \hline <br /> x &amp; x &amp; x+1 &amp; x+2 &amp; x+3 \\<br /> x+7 &amp; x+7 &amp; x+8 &amp; x+9 &amp; x+10 \\<br /> x+14 &amp; x+14 &amp; x+15 &amp; x+16 &amp; x+17 \\<br /> x+21 &amp; x+21 &amp; x+22 &amp; x+23 &amp; x+25 \\ \hline \end{array}
The instructions force us to select four numbers whose sum
is the sum of the eight numbers on the perimeter.
  • · Replies 32 ·
  • · Replies 30 ·
