MHB Cammie's question from Facebook (finding a mixture through systems of equations)
A girl scout troop needs to mix 20 pounds of candy worth 80 cents per pound with candy worth 50 cents per pound to create a mixture that can be sold at 60 cents per pound without profit or loss. By setting up equations based on the total value of the candies before and after mixing, the solution reveals that 40 pounds of the 50-cent candy must be added. This was achieved through the elimination method, resulting in the equation x = 40. The process also demonstrates the concept of a weighted average to confirm the solution. Ultimately, the troop requires 40 pounds of the cheaper candy for the desired price point.
Jameson
Insights Author
MHB
A girl scout troop has 20 pounds of candy worth 80 cents per pound. the troop wishes to mix it with candy worth 50 cents per pound so that the total mixture can be sold at 60 cents per pound without any gain or loss. how much of the 50 cent candy must be used? Solve by elimination.
Mathematics news on Phys.org
Hello Cammie,
Let's let $T$ be the total value of the two candies in dollars, and $x$ be the amount in pounds of the 50-cent candy that must be used to meet the stated goal.
Before mixing, we may state the combined value of the two candies as:
$T=20\cdot0.80+x\cdot0.50$
and we may arrange this as:
(1) $2T-x=32$
After mixing, we may state the total value of the mixture as:
$T=0.60(20+x)$
which we may arrange as:
(2) $5T-3x=60$
To eliminate $T$, we may multiply (1) by 5 and (2) by -2 and add them to get:
$x=40$
Thus, we have found the troop needs to add 40 lbs. of the 50-cent candy to the 20 lbs. of 80-cent candy to get a mixture that can be sold for 60 cents per pound without any gain or loss.
You may be interested to know that what we have done is equivalent to using a weighted average to solve the problem:
$\displaystyle \frac{20\cdot0.80+x\cdot0.50}{20+x}=0.60$
$\displaystyle 20\cdot0.80+x\cdot0.50=0.60(20+x)$
Do you see that this is $T=T$?
$\displaystyle 16+\frac{1}{2}x=12+\frac{3}{5}x$
$\displaystyle 4=\left(\frac{3}{5}-\frac{1}{2} \right)x=\frac{1}{10}x$
$\displaystyle x=40$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
