Can 2^n Always Be Greater Than n for Natural Numbers?
The discussion revolves around proving that for all natural numbers n, 2^n is greater than n using mathematical induction. The base case is established easily, and the inductive hypothesis assumes 2^k > k. The challenge lies in demonstrating that 2^(k+1) > k+1, which can be rewritten as 2^k * 2 > k + 1. Participants emphasize the importance of maintaining the inequality without dropping terms, suggesting that since 2^k > k, it can be used to show that 2^k * 2 also exceeds k + 1. The conversation highlights the nuances of mathematical induction and the need for careful manipulation of inequalities.
amiv4
Prove that for all the natural numbers n that 2^n > n
Base Case is easy
Then the inductive step you have 2^k > k as the inductive hypothesis
show that p[k+1] holds
2^(k+1) > k+1
on the left side 2^(k+1) = 2^k * 2
but idk what else to do
Base Case is easy
2^(k+1) > k+1
And what does your induction hypotheses tell you about the 2k on the right side of that last equation? And after you answer that, what are you wanting thge right side of the inequality to be greater than?
Well 2^k * 2 > 2^k > k. And I am guessing you are talking about k+1 and idk what i want that to be greater than. It is greater than k but idk how that helps
amiv4 said:
Well 2^k * 2 > 2^k > ... And I am guessing you are talking about k+1 and idk what i want that to be greater than. It is greater than k but idk how that helps
But you are giving away something by dropping the 2. You have:
2k+1 = 2k*2 so far, and you know 2k > k
Use that without dropping anything else and see if you can see the result is > k + 1.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
