Can a 2-Pole Motor Handle 600 Tons? VFD and Motor Question - Expert Opinions
  • Thread starter Thread starter vsdguy
    Motor Vfd
A 75kW 2-pole motor has been connected to a VFD intended for a 75kW 4-pole motor, raising concerns about its ability to handle a 600-ton load. The torque output for the 2-pole motor is 240Nm, while the 4-pole motor provides 480Nm, indicating the 2-pole may not generate sufficient torque for the application. The user is seeking expert opinions on whether the 2-pole motor can sustain the required load or if a switch back to a 4-pole motor is necessary. Testing the setup is suggested, but the user is unable to do so due to distance. The discussion highlights the importance of matching motor specifications to application requirements for optimal performance.
vsdguy
Hi all,
I have a 75kW high load Ac drive and a 75kW 4 pole 3 phase motor that is supposed to be used for a winch pulling horizontaly.
The customer connected the Vfd to a 75kW 2 pole 3 phase motor.
Now the question is will this 2 pole motor be capable to develop enough torque to pull a load of 600 Tons?
The Torque Loads for a 2 pole is 240Nm and for a 4 pole its 480Nm.
Do I have to change the motor (back to a 4 pole)?
Just wanted a second and third opinion from you all.
Kind Regards,
vsdguy
If it is already hooked up, couldn't you just try it?
I am like a 1000 miles away from the motor and the drive. Customer called that by mistake they received a 2pole instead of a 4 pole. I was just curious if someone ran into a similar experience. The application is for pulling vesels and loads at the worst case scenario 600 tons.
As I mentioned earlier will I have enough torque that will sustain that load.
Any help would be beneficial.
vsdguy
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
