Can a Microcontroller Replace a 555 Timer for a Low Frequency Flasher?
  • Thread starter Thread starter funnyguy
    Frequency Timer
Using a microcontroller instead of a 555 timer for a low frequency flasher can provide greater flexibility in timing and duty cycle adjustments, potentially making it more cost-effective. Concerns about the cost of resistors and capacitors for achieving low frequencies may be unfounded, as they are generally inexpensive. Alternatives like a Wien bridge oscillator or a PWM signal for motor control were also suggested. The discussion highlights the importance of considering various timing solutions based on project needs. Ultimately, the choice between a microcontroller, a 555 timer, or other options will depend on specific requirements and available resources.
funnyguy
I want to build a low frequency, uneven cycle flasher somewhere around 10 seconds on, 5 seconds off. I planned on using a 555 timer and a MOSFET to drive my load, a small DC motor. Are there any other suggestions for something at low frequency? I'm just concerned at the R and C values needed for such low frequency as I might be able to buy a cheaper timer already assembled.
Thanks.
Thanks.
Do you expect that since you need such timing control for your 555 that "the R and C values needed" will be expensive? What is the cost of one resistor and one capacitor combined?
A cheaper timer might be constructed by placing a gerbil on a rotary treadmill. You could mount a contactor near the circumference to energise a microswitch each revolution. You'd need to teach the gerbil the correct timing, and also feed him or her, so it might be cheaper to stick with the 555 timer.
Cheers,
Bobbywhy
I believe what bobbywhy is saying, is that one R and C probably aren't going to cost you that much.
Use Mouser.com to find some L and C with $ values.
http://www.mouser.com/Passive-Components/Capacitors/_/N-5g7r/
http://www.mouser.com/Passive-Components/Inductors/_/N-5gb4/ Also, you could try using an oscillator. I would suggest a Wien bridge oscillator.
http://en.wikipedia.org/wiki/Wien_bridge_oscillator
That way, you would buy 2 R and 2C instead of one C and one L
You would have to change the duty cycle of the Wien Bridge oscillator. I am trying to find the circuit for that...
Well, I didn't think they would, but I think the original documentation and formulas I had misled me. Originally, I looked at the calculations and thought that even with R values in the 100 kohm ranges I would need very large $5+ capacitors to make the high time what I needed. I see now that even with 7.5k and a 1mF cap I'll be in the range I need.
I would suggest considering using a microcontroller instead of a 555 timer for your low frequency flasher. This would allow for more flexibility in adjusting the timing and duty cycle, and may also be more cost-effective in the long run. Additionally, you could potentially use a pulse width modulation (PWM) signal to control the speed of the DC motor, rather than using a MOSFET. This would also give you more control over the motor's speed. Alternatively, you could consider using a different type of timer, such as a 555 timer with an adjustable resistor, or a 555 timer with a potentiometer, to achieve your desired frequency. Ultimately, the best approach will depend on your specific project requirements and resources.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
