Can a Permanent Magnet Hoverboard Work on a Magnetic Floor?
  • Thread starter Thread starter spikie1
    Hoverboard Magnet
The discussion centers on the feasibility of building a permanent magnet hoverboard that can float on a magnetic floor. The creator has designed a board with closely packed holes for magnets and is considering a similar setup for the floor. Key concerns include the implications of Earnshaw's theorem on stability, the potential for the board to flip due to the size and arrangement of the magnets, and whether the walls of a rink could prevent the board from leaving the magnetic field. The creator hopes that using approximately 400 magnets, each providing 250g of lift, will be sufficient to elevate a person without flipping the board. Additionally, they plan to incorporate a flywheel for steering and seek advice on the necessary mass for effective gyroscopic action.
spikie1
Ive had a look through the forums regarding this subject but I've found more questions than answers to issues that i would like to know
firstly I am planning on building a perminant magnet hoverboard that floats on a perminant magnet floor
slightly crazy i know
the board is a skateboard in size I've covered it in holes 10mm dia 5 mm deep with a 6 hole pcd of 13mm so they are very closely packed together I've done this with a cnc mill so they are pretty accuratly spaced I am planning on doing the same with the floor was going to use a full sheet of ply as a starter
Now for some questions i know Earnshaws theorem won't allow a stable floating magnet in a stable field etc
but if the field is wide enough ie an ice rink i wouldn't slip out of the field as there are walls around the edge of the rink? Is that true would it work? Also issue with board flipping because of size of magnets been used approx 400 on a board would it flip because there isn't enough energy to flip board because there force only exerts over a small range individualy about 250g over about 10mm repulsively
so if boards can't flip because of range of the repulsive force even if it did the amount of force on the other side if the board is reduced due to the thickness of the board
and the board can't leave the field because there are walls around the rink
Would it work? Or would fields combine amoung small magnets etc
i haven't been able to find any info on fields in magnetic arrays and i don't really want to spend a huge anount on magnets just to find out that that there are other forces at work that I am unaware of
im hoping that 400 ish magnets each with 250g of lift will be enough to elivate a person 10mm and not flip the board and the walls around the rink will stop the board leaving the field
the floor will be same spacing and same magnets as board
I forgot to mention i am also planning on mounting an enclosed flywheel on the front of the board in the hope that i can use the gyroscopic action of it to provide some steering by tilting the board I am hoping it will pull the nose left and right anyone know how much mass ill need in this?
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
