I Can a Tower of Books Move with Lighter Forces?
The discussion centers on the mechanics of a stack of books and the forces acting on them. It clarifies that the "last book" refers to the bottom book in the stack, which exerts a force on the surface equal to N=nmg. When considering the application of force, the placement of that force affects the motion of the stack, as pushing below the center of mass is generally easier than at the top. The conversation also emphasizes the importance of clear terminology, suggesting the use of "top book" and "bottom book" for clarity. Overall, the interaction of forces in a stack of books is complex and influenced by the distribution of weight and the point of force application.
Clockclocle
Suppose n book stack on each other. Since each book have the same weigh then the last book exert a force N=nmg on the surface so it has the biggest static friction. But if we treat the whole tower of books as one particle it also has N=nmg. This mean if we exert enough force in the last book, the tower keep moving as we exert lighter force on all the book at the same time?
The last book does not make contact with the surface. It exerts a friction force only on the book it's on top of.
What? I think the last book would both contact with the surface and the top of it?
I think the OP is using "last book" to mean the one at the bottom of the stack. (I would call the top one the last book, since it was the last one placed on the stack, but the question makes more sense if it means the bottom book.)
In that case, the answer to the question depends on what idealisation you make. If you idealise the books as non-compressible and much wider than the stack is tall so there's no significant difference in torque between the two cases, then yes you can get the same motion by applying ##n## forces of magnitude ##F## or one of magnitude ##nF##.
In reality, books are typically slightly compressible and a stack of books will frequently be taller than it is wide. In that case where you apply the force matters because it will change how the weight is distributed which may affect how easily it slides. It's a fairly common experience that pushing something at a point below its center of mass is easier than pushing it at the top.
This is not possible: you can place a book on top of another book, but then the lower book is not on top of the top one. Langauge .. :rolleyes:
It seems we mean different things when we mention 'the last book'. Langauge ... :rolleyes:
Easier to only use 'top book' and 'bottom book'. Even better to make a sketch to clarify.
Could you now clarify your question ? I have difficuty understanding the last part...
(and let's assume the books all behave as identical ideal incompressible blocks, with a friction coefficient ##\mu## -- both between books and between bottom book and table. OK?)
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
