Can a type K thermocouple be used with cryo?
  • Thread starter Thread starter jonhswon
    Thermocouple
Type K thermocouples are generally not suitable for cryogenic temperatures due to their non-linear characteristics and calibration limitations. While they can be calibrated using liquid nitrogen and ice, inaccuracies arise because they are typically calibrated only at higher temperatures, leading to unreliable extrapolation. The discussion highlights that other sensors, like silicon diode sensors, are preferred for cryogenic applications. Additionally, the Seebeck effect does not vanish at the temperatures discussed, as superconductivity in metals occurs at much lower temperatures than those relevant for liquid nitrogen. Overall, while type K thermocouples can be used, they are not the optimal choice for accurate cryogenic temperature measurements.
jonhswon
Hi.
I can not understand why type K tc can not be used with cryogenic temperatures?
If for example calibrated with liquid nitrogen and ice, can it be used from 0 C to -200 C accurately?
I understand that there is a non-linear characteristic a lower temperatures, but then one could make a voltage-to-temp plot by calibrating against ice, liquid nitrogen, solid ice, etc.. and obtain a curve.
Does the inaccuracy arise simply because they are usually calibrated with ice and boiling water only, then linear interpolation/extrapolation line is drawn, OR is there something else that I am missing?
Maybe the metals or the alloy junction are superconductors at cryogenic temperatures.
Does the Seebeck effect vanish, or the calibration change, in superconductive metals?
No, not at the temperatures mentioned in the OP (liquid nitrogen). There are very few metalsa/alloy that become superconducting even at liqduid helium temperatures (Nb, NbN, Pb and some alloys); there are none at liquid nitrogen temperatures.
For the type of metals that thermocouples are made you typically have to go to mK temperatures; and not all metals become superconducting even then.
The Lakeshore link has an error (I think): The page claims a Type K sensitivity of 4.1 mV/K @ 20K. I think they meant 'uV.'
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
