- #106
Smacal1072
- 59
D H said:Sure. It might take a long time, however. You have just choked off convection, so about all that is left is diffusion. Diffusion is a very slow process. This might be a part of klimatos' issue. As an atmospheric scientist, he views a situation in which the lapse rate is smaller than adiabatic as indicative of a stable atmosphere. There is little convection in such situations, almost none in the case of a temperature inversion. (That's why Los Angeles has such a problem with smog.)Smacal1072 said:The question Striphe is posing is: If we disturb this equilibrium (say, by momentarily enforcing the top and bottom to be the same temperature), and then allow the system to relax to equilibrium again, will the temperature gradient re-emerge?
Why am I so sure? For a fixed amount of total energy, entropy will reach a maximum under isentropic conditions. The second law of thermodynamics dictates that this is the equilibrium condition of this isolated system.
I guess that's the point of confusion then. I did a little digging, and found an excerpt from Maxwell's "Theory of Heat" (pg 300-301):
James Clerk Maxwell said:...If two vertical columns of different substances stand on the same perfectly conducting horizontal plate, the temperature of the bottom of each column will be the same; and if each column is in thermal equilibrium of itself, the temperatures at equal heights must be the same. In fact, if the temperatures of the tops of the two columns were different, we might drive an engine with this difference of temperature, and the refuse heat would pass down the colder column, through the conducting plate, and up the warmer column; and this would go on till all the heat was converting into work, contrary to the second law of thermodynamics.
This sort of summarizes one of the apparently paradoxical situations we thought up earlier. (I honestly just stumbled upon this today). Since we know that 2 columns of different substances "at equilibrium of itself" do have temperature gradients, it falls into Maxwell's paradox above.
