Can an object be halfway between focal point and diverging mirror?
An object cannot be halfway between the focal point and a diverging mirror because the focal point of a diverging mirror is located behind the mirror. Consequently, this would place the object behind the mirror as well, which is not feasible in standard optics. The discussion references a problem from a physics text that contrasts converging and diverging mirrors, highlighting the unique characteristics of each. It notes that the scenario described may only occur when mirrors are combined with other optical elements. Thus, in isolation, an object cannot occupy that position relative to a diverging mirror.
Negatratoron
A physics question from Principles of Physics by Mazur in the chapter on Optics is asking me to "repeat Problem 92 for a diverging mirror", and one of the questions in Problem 92 (which is about a converging mirror) is to find the image distance of an object halfway between the focal point and the mirror.
I do not believe this is possible, since the focal point of a diverging mirror is behind the mirror, and so an object halfway between the focal point and the mirror is also behind the mirror.
Science news on Phys.org
I think I figured it out. Table 33.2 in the text has a footnote in the "o < 0" case: "Encountered only with lens or mirror combinations". If any mirror is in combination with other mirrors and lenses, it may be the case that the object is behind the mirror.
Thread 'Simple math model for a Particle Image Velocimetry system'
Hello togehter, I am new to this forum and hope this post followed all the guidelines here (I tried to summarized my issue as clean as possible, two pictures are attached). I would appreciate every help: I am doing research on a Particle Image Velocimetry (PIV) system. For this I want to set a simple math model for the system. I hope you can help me out. Regarding this I have 2 main Questions. 1. I am trying to find a math model which is describing what is happening in a simple Particle...
Thread 'How to model converging illumination through object plane (in ZEMAX)'
Hello community, I'm designing a projection lens system for a 35mm film projector in Zemax OpticStudio and struggling with the correct sequential mode setup for the illumination geometry. The light source is a Xenon short-arc lamp reflected by an ellipsoid mirror, which creates a converging cone with a 40.6 degree full angle that passes through the film gate. The film gate is my object plane, but the light doesn't diverge from it like a typical Lambertian source. Instead, the converging...
