Can anyone explain to me why eigenvector here is like this
The discussion centers on finding eigenvectors and eigenvalues for a matrix A, where the eigenvalues identified are 2, 12, and -6. A participant is confused about obtaining the eigenvector [0, 0, 1] for the eigenvalue -6, questioning its validity since multiplying it by the matrix results in the zero vector. It is clarified that the matrix used in calculations is actually A - (-6)I, leading to the conclusion that the kernel of this matrix should not consist solely of the zero vector. An eigenvector must be a non-zero vector, indicating that [0, 0, 1] is indeed valid as an eigenvector for the eigenvalue -6. The discussion emphasizes the importance of correctly applying the definition of eigenvectors in relation to the eigenvalue equation.
sozener1
Im supposed to find the eigenvectors and eigenvalues of A
I found that eigenvalues are 2 12 and -6
then I found eigen vectors substituting -6 to lambda
and someone has told me I get 0 0 1 for eigenvector which I cannot understand why??
can anyone pleasezzzzzzzz explain why this is?
Mathematics news on Phys.org
Did you multiply this vector with your matrix? What do you get?
Does this fit to the definition of an eigenvector?
I get 0 0 0
it doesn't fit with the definition of eigenvectors
so does that mean it should be 0 0 0 instead of 0 0 1??
I mean when you try to calculate for v3 = [ v1 v2 v3]
since the last row of the matrix is 0 0 0 should v3 come out as 0?? couldn't v3 be any number??
sozener1 said:
I get 0 0 0
That's not what I get.
The matrix you showed in the second attachment is not A. It is [A - (-6)I]. Of course if you multiply this matrix times your eigenvector, you'll get the zero vector.
Assuming that your eigenvalue is λ and that x is an as-yet unknown eigenvector for λ, what you're doing is solving the equation Ax = λx for x. That's equivalent to solving the equation (A - λI)x = 0. In other words, of finding the kernel of the matrix A - λI. This should be something that you have already learned to do.
The kernel here should not consist of only the zero vector - an eigenvector cannot be the zero vector.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
