Can anyone help me out with von Neumann entropy please?
In summary, calculating von Neumann entropy for a system that is part of a bigger system can be done by using the reduced density matrix and the formula for von Neumann entropy. However, it is important to normalize the reduced density matrix before using it for calculations. It is also expected to get different entropy values when reducing the matrix for different subsystems, but the average entropy over a period of time should be the same.
lhj2010
Can anyone help me out with von Neumann entropy please??
I've been wondering if I could be able to calculate the entropy of a system which is part of a bigger system.
For example, let's say that there's a cavity and two atoms(atoms are two-level system).
The hamiltonian of the system would roughly be like this;
[tex] \[
H = \sum_{j} \omega s_{jz} + \omega a^{\dag} a + \sum_{j} g ( s_{j-} a^{\dag} + s_{j+} a ),
\][/tex]
And you know the density matrix. I put the state in this form;
[tex] \[
|\Psi \ket = |\Psi_{atom1} \ket \otimes |\Psi_{atom2} \ket \otimes |\Psi_{cav} \ket = a|1_1, 0_2, 0_3 \ket + b|0_1, 1_2, 0_3 \ket + c|0_1, 0_2, 1_3 \ket
\][/tex]
where 1 is atom1, 2 is atom 2, and 3 is a cavity.
and got this density matrix;
[tex] \[
\rho^{ABC} =
\left( {\begin{array}{ccc}
|a|^2 & ab^\ast & ac^\ast \\
a^\ast b & |b|^2 & bc^\ast \\
a^\ast c & b^\ast c & |c|^2 \\
\end{array} } \right)
[/tex]
Now, I'm trying to see the entropy between the two atoms, and I was wondering about this. I don't know if it's really simple thing or something that's not really been cleared.
First, I thought I had to reduce the matrix to kill the degree of freedom of the cavity. Which gives me this.
[tex] \[
\rho^{AB} =
|a|^2 & ab^\ast & 0 \\
a^\ast b & |b|^2 & 0 \\
0 & 0 & |c|^2 \\
\][/tex]
Then I thought now I had to reduce the matrix once more in order to evaluate the entropy. And this gives me a funny result. By choosing different atom to reduce, we get different entropy. The average entropy in a period is the same, but shouldn't it be identical at any time?? I mean, it's the same system. Is there some kind of restriction when you use reduced matrix for entropy like, 'you shouldn't use the reduced matrix to reduce it for the entropy' or something like that?
I really don't know if I'm beeing stupid or anything, but even if I am, let me know.
Thanks in advance! :D
Hello! Calculating von Neumann entropy for a system that is part of a bigger system can be a bit tricky, but it is definitely possible. First, it's important to understand that entropy is a measure of the amount of uncertainty or randomness in a system. In quantum mechanics, this uncertainty is represented by the density matrix, which you have already calculated for your system.
To calculate the entropy between the two atoms, you can use the reduced density matrix as you have done. However, it's important to note that the reduced density matrix needs to be normalized before using it to calculate entropy. This means that the sum of the diagonal elements in the reduced density matrix should add up to 1. In your calculation, this would mean dividing the reduced density matrix by the sum of the diagonal elements.
Once you have a normalized reduced density matrix, you can use the formula for von Neumann entropy, which is given by S = -Tr(ρ ln ρ), where Tr is the trace operator. This will give you the entropy between the two atoms in your system.
As for your observation about getting different entropy values when reducing the matrix for different atoms, this is actually expected. The reduced density matrix depends on which subsystem you are considering, and therefore the entropy will also depend on which subsystem you are calculating it for. However, as you mentioned, the average entropy over a period of time should be the same, as the system is the same.
I hope this helps! Let me know if you have any further questions.
Related to Can anyone help me out with von Neumann entropy please?
1. What is von Neumann entropy?
Von Neumann entropy is a measure of uncertainty or randomness in a quantum system. It was introduced by physicist John von Neumann and is commonly used in quantum information theory to quantify the amount of information contained in a quantum state.
2. How is von Neumann entropy calculated?
The formula for calculating von Neumann entropy is S = -Tr(ρ ln ρ), where S is the entropy, Tr is the trace operator, and ρ is the density matrix of the system. This formula reflects the idea that entropy is a measure of the spread of probabilities in a system.
3. What is the significance of von Neumann entropy?
Von Neumann entropy is important in quantum information theory as it allows for the quantification of information in quantum systems. It is also used in quantum thermodynamics to measure the amount of heat or disorder in a system.
4. How does von Neumann entropy differ from classical entropy?
In classical systems, entropy is a measure of disorder or randomness in a system. However, in quantum systems, the concept of entropy is more complex as quantum states can exist in superposition, meaning they can have multiple possible values at the same time. Von Neumann entropy takes into account this quantum behavior and is a more accurate measure of uncertainty in quantum systems.
5. Can von Neumann entropy be negative?
Yes, von Neumann entropy can be negative. This occurs when the entropy of a system is less than the maximum possible entropy, indicating that the system is not completely random or uncertain. This can happen in certain quantum systems, such as entangled states, where there is a correlation between particles that reduces the overall uncertainty of the system.
  • Quantum Physics
  • Quantum Physics
  • Linear and Abstract Algebra
  • Quantum Physics
22K
