MHB Can anyone tell me the real names of these 3D shapes?
  • Thread starter Thread starter goldieluxe
    3d Shapes
The discussion centers on identifying the names of specific 3D shapes, particularly focusing on the terms "cuboid" and "rectangular prism." Participants clarify that a cuboid is a convex polyhedron with six quadrilateral faces, while a rectangular prism is a more specific type of cuboid with rectangular faces and right angles. There is debate over the precision of the term "cuboid," with some arguing it is ambiguous compared to the well-defined terms like cube and right rectangular prism. The original poster's diagram does not specify right angles or square faces, leading to differing interpretations of the shapes. Ultimately, the conversation highlights the importance of precise terminology in geometry.
goldieluxe
I know cylinder, cone and cube, but can't think of the names for the last two. I know this is a very basic question that I should know...but I am blanking. View attachment 6204
Mathematics news on Phys.org
The last two are prisms, a rectangular prism and a right triangular prism.
Second last one is precisely known as cuboid and the last one is a triangular prism (as MarkFL said).
I don't think there's anything precise with the term "cuboid" as it simply means "cube-like". "Rectangular Prism" is much more specific, as being a 3D shape with all identical rectangular cross-sections...
If a name has been given to a 3D shape by ancient mathematicians, why not use it? A square will be called a square, not a rectangle with all sides equal. :)
From wiki:
In geometry, a cuboid is a convex polyhedron bounded by six quadrilateral faces, whose polyhedral graph is the same as that of a cube. While mathematical literature refers to any such polyhedron as a cuboid,[1] other sources use "cuboid" to refer to a shape of this type in which each of the faces is a rectangle (and so each pair of adjacent faces meets in a right angle); this more restrictive type of cuboid is also known as a rectangular cuboid, right cuboid, rectangular box, rectangular hexahedron, right rectangular prism, or rectangular parallelepiped.[2]
So for starters "cuboid" is somewhat ambiguous, and more specifically mathematical literature refers to it without requiring right angles or square faces, while cube and right rectangular prism are well-defined with square respectively rectangular faces.
Ancient mathematicians also believed that all numbers were rational and killed anyone who could prove otherwise. Yes, why not use their logic?
I like Serena said:
From wiki:
Does the diagram posted by OP specify right angles or square faces?
Also, how would you define a cuboid?
Examples of cuboids... I think they look different from what is shown in the OP...
They 'look' different, but it is nowhere specified in the original diagram by OP that all angles are right angles and 4 faces are rectangular. Since it is not specified, cuboid is the most appropriate name for the shape. In a case that it had been specified, it could have been called as rectangular cuboid.
