Can Bi-Quadratic Equations Be Represented in 3-Dimensional Graphs?
  • Thread starter Thread starter Windseaker
    Curve Curves
Bi-quadratic equations can be represented in 3-dimensional graphs, with Z defined as a function of X and Y. The equation Z = a + bX + cX² + dY + eY² + fXY describes a surface in three-dimensional space. To visualize this in two dimensions, one can create contour plots in the XY plane or take slices by setting either X or Y to a constant value. This approach allows for overlapping graphs or simplified representations. Utilizing these methods can effectively illustrate the relationships within the bi-quadratic equation.
Windseaker
Trying to solve a bi-quadratic eq. so I can graph in in x and y , but Z means this is a 3-D graph? , is it possible to have a overlapping graph or any ideas?? X= +100 &-100
Z= a + bX + cX² + dY + eY² + fXY
Mathematics news on Phys.org
The equation Z= represents a surface in 3 space, as a function of X and Y. What are you trying to solve?
Im trying to break the equation into two parts to graph on a two dimensional axis or overlap the two on one graph, any ideas on dividing the equation into two??
It depends what you what to show. You could make a contour plot in the xy plane. Or take a slice along some other plane. Just set x or y to a constant and it becomes a 2D graph.
too easy, thank you
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
