Can black holes absorb at an infinite rate?
In summary, the conversation discusses the possibility of a black hole taking in all matter, including a rod of hard metal approaching it at nearly light speed. It is debated whether the momentum of the rod would be transferred to the black hole or some of the matter would pass through by virtue of its inertia. The conversation also explores the concept of energy conversion and the effects of the black hole's gravitational force on the approaching rod. The event horizon is mentioned as the point of no return, with the discussion of its effects on approaching matter becoming more interesting when considering the quantum nature of black holes.
nanoWatt
88
This is theoretical, but if we had a black hole with event horizon of radius R, and passed in a continuous stream of stellar matter with a radius of 99% of R or so,
would the black hole take in everything, no matter how fast it was moving?
For example, we have a sufficiently long rod of a hard metal (let's say a few light-years long), with a radius near the size of the event horizon. If this rod were rammed into the black hole at nearly light speed, would it just eat up all of it. Or is it possible that some would pass through by virtue of it's momentum or inertia?
Likes Xylok
Astronomy news on Phys.org
The rod would not pass through. The momentum would be transferred to the black hole - it would move in the direction of the incoming rod.
Likes Xylok
So we're talking a 100% energy conversion, virtually instantaneously as the horizon is crossed?
Likes Xylok
This also brings up an interesting question about what happens at the event horizon. It is generally said that objects approaching the event horizon appear to slow down, and never appear to cross the horizon. What would we see if we pushed this very long rod itno the black hole? ould the end near the EH appear to stop while the rest of the rod appears to keep moving forward at very high speed, while no bunching up in the middle occurs?
This makes me think that the gravitational force would affect the metal rod even before it crosses the horizon. There was a physics show on tv that mentioned if a black hole was as close to us as Jupiter, we would experience earthquakes on Earth.
I always have to remember there is the conservation of energy. However, when dealing with the QM nature of black holes, this becomes more interesting.
The event horizon is the point of no return as it were. But the gravitational force of the black hole will be acting on the rod all the time as it approaches. I'm not sure what the show was referring to but it would depend entirely on the mass of the black hole.
Related to Can black holes absorb at an infinite rate?
1. Can black holes absorb matter and energy at an infinite rate?
The short answer is no. Black holes have a maximum rate at which they can absorb matter and energy, known as the Eddington limit. This limit depends on the mass of the black hole and is equivalent to approximately 10^36 kilograms per second.
2. Will a black hole eventually consume everything in the universe?
No, a black hole's growth is limited by the amount of matter and energy in its vicinity. While it may continue to grow in size, it will not consume all matter in the universe.
3. Can a black hole absorb light?
Yes, black holes are known for their strong gravitational pull, which can even capture light. This is why they appear as dark regions in space, as they absorb all light that enters their event horizon.
4. Can a black hole absorb other black holes?
Yes, if two black holes come close enough to each other, they can merge and form a larger black hole. This process is known as a black hole merger and is thought to occur when two galaxies collide.
5. Is there a limit to the size of a black hole?
Yes, there is a theoretical limit known as the Schwarzschild radius, which is the point at which the escape velocity of a black hole is equal to the speed of light. Beyond this point, known as the event horizon, nothing can escape the black hole's gravitational pull.
  • Astronomy and Astrophysics
