Can Calorimeters Measure Enthalpy Variation of Fast Reactions?
The discussion centers around the limitations of calorimetry in measuring enthalpy changes for various types of reactions, particularly fast reactions. It highlights that calorimeters struggle with fast reactions due to the rapid release or absorption of heat, which can lead to inaccuracies in measurement. While some participants suggest that methods exist to delay reactions, the consensus is that the speed of heat flow in fast reactions poses a significant challenge. Additionally, the issue of very slow reactions is noted, as they require impractically long times to reach equilibrium, making calorimetry less feasible. Overall, the conversation emphasizes the complexities involved in accurately measuring enthalpy changes across different reaction rates.
Sonim
TL;DR Summary
Enthalpy , Calorimeter and Hess Law Question Related
First of all this is a question that I had while reading some concepts of my book, so this isn't a homework question. I have started reading the thermochemistry chapter of my book, and it shows the story of Hess' Law and says that it was created is because a calorimeter can't be used to measure the enthalpy variation of too slow reactions, explosive reactions, fast reaction and multi-step reactions. Why can't it be used to calculate the enthalpy variation of fast reactions ?
Chemistry news on Phys.org
What are your thoughts on this?
Likes berkeman
Actually, I think the opposite. There are ways to delay reactions, so this shouldn't be a problem. Maybe it lies on the fact that fast reactions releases/absorbs heat too fast, which results in the increase of heat flow. However, it shouldn't be a problem too, because the termometer in the calorimeter would release/absorb more heat in less time as well. Have you got any idea?
I agree with you on the fast reactions. However, on very slow reactions, no one has the time to wait days or weeks or years for the reaction to reach equilibrium. But, otherwise, like you, I don't see major problems.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
