Java Can compareTo Handle All String Comparisons in Java?
  • Thread starter Thread starter tbrown427
    Java
The Java code provided is intended to compare two strings, "rabbits" and "capes," using the compareTo method. However, the output is consistently "capes rabbits" regardless of the comparison result. This occurs because both the if and else branches contain the same print statement, leading to no variation in output. To achieve the intended functionality, the code should differentiate the outputs based on the comparison result, ensuring that different messages are printed for each condition. The current structure fails to utilize the comparison effectively, resulting in a lack of meaningful output.
tbrown427
I can't get this to test all the way through
Code:
import java.util.Scanner;
public class OrderStrings {
   public static void main (String [] args) {
      String firstString;
      String secondString;
      firstString  = "rabbits";
      secondString = "capes";
     if (secondString.compareTo(firstString) >0){
         System.out.println("capes rabbits");
     else {
      return;
Technology news on Phys.org
This code compiles and executes, but the output is always
capes rabbits
Look at your if else statement and notice it makes no difference the result of compareTo; it always just prints the above.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
15K
13K
