I Can configuration space be observer independent?
The discussion centers on the formulation of configuration space in a way that is independent of observers and coordinates. It is noted that while spacetime can be described in an observer-independent manner, the configuration space often appears to depend on specific observers and coordinates. The example of a pendulum's configuration space being represented as S^1 raises questions about why configuration space would be observer dependent. The inquiry seeks a method to define configuration space that aligns with the observer-independent nature of spacetime, suggesting that a more universal definition could be crafted from the fundamental properties of the system. The conversation highlights the need for clarity on how to achieve this observer-independent formulation of configuration space.
lriuui0x0
We can formulate the spacetime in an observer/coordinate independent way, i.e. a particle becomes a worldline in the 4d space. Then relative to each observer, the worldline can be casted to a function in R^3. However, I haven't found any reference on formulating configuration space in a coordinate independent way. It seems that the configuration space is formed in a way with a particular observer and some particular coordinates for the state of the system. Just want to ask if there's such a concept as observer independent configuration space?
I don’t understand. Why would configuration space be observer dependent?
An example could clarify the question I guess.
Say, the configuration space of the pendulum is ##S^1##. Which observer does see anything else?
I just don't usually see coordinate independent formulation of the configuration space.
By definition a Lagrangian system is a pair (L,M), where M is a smooth manifold called the configuration space and ##L: TM\to \mathbb{R}## is a smooth function
ok?
ok?
Sorry, the question may sound a bit weird. I will try to give a more detailed explanation on what structure I have in mind before rasing the question.
So first, we have a 4d spacetime, there are n worldlines in the spacetime representing n particles forming a system with certain interation. There might be constraints at each spatial slice, such as the distance between two particles maintain the same.
These definitions are observer independent that fully describe the system, so if the configuration space is also observer independent, we should be able to derive the configuration space structure purely from the above. My question is how to craft such a definition?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
