Can Copper Alloys Be Electropurified to Achieve 99.99% Pure Copper?
  • Thread starter Thread starter amarnath
    Copper
Electropurification of copper alloys containing 50% to 90% copper to achieve 99.99% pure copper is theoretically possible, but presents challenges due to differing reduction/oxidation potentials of alloy constituents. While electrolytic refining is effective for blister copper, the complexity increases significantly with multiple alloying elements, complicating the control of the process. The discussion highlights the need for optimal current density for economic large-scale operations and mentions the potential use of commercial electrolytic cells. The focus remains on the feasibility of refining copper alloys rather than their initial preparation. Overall, further exploration into the specifics of electrolytic refining for copper alloys is necessary for practical application.
amarnath
Hi all,
I know in copper mining industries copper which is at 99% pure ( Blister copper ) which is electropurified to 99.99% by simple electrochemical cell consist of copper sulfate as electrolyte bath along some sulfuric acid in it.
My question is it possible to do this same process say for eg to electropurify a alloy of copper + other metals in which copper will be 50 to 90 % of composition to get pure copper from copper alloy by electropurification possible . Pls advice
If possible can pls elaborate optimium current density for such process to be economical at large scale (Also helpful if advice any commerical avaliable electrolytic cells for large scale operations ) i need to electropurify a copper alloy with 50 to 90% copper to get pure copper 99.99% . pls help me with as much as details possible. Good lucks to all
As far as I know, metal 'alloys' are prepared by melting. If one wants ultrapure metal (alloy), it would be melting in a vacuum (Vacuum arc melting) and usually triple melted, i.e. 3 successive meltings. One would start with metals as pure as possible.
Electrolytic refining is a problem because each element has a different reduction/oxidation potential, and that would be difficult to control. For two elements, and even more so as the number of alloy consituents increase.
Its not about preparation of alloys
Hi Astronuc,
Thanks for a answer. My actual question is not regarding preparation of ultrapure alloy's but its about electrolytic refining of alloy into constituent metals.
If electrolytic refining of alloy ie. blister copper to pure copper is if problem why its employed commerical and as economically feasible operation , so pls let me know is such same process can be employed with say 50% copper alloy to pure copper
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
