Can dark matter explain the flyby anomalies?
Zz, the moon's influence was taken into account in the analysis of the flyby anomalies. However, some have proposed that special relativity and transverse Doppler shift could explain the anomalies without needing to question general relativity or invoke exotic explanations like dark matter.
SF
The flyby anomalies, you may remember, are a set of fascinating data indicating that spacecraft flying past Earth undergo a strange, step-like change in their acceleration.
The Galileo, Near, Cassini and Rosetta spacecraft all seem to have been hit by this weird phenomenon and while that’s not a large number of data points, it is an impressive proportion of the few spacecraft that have flown past Earth on their way to other parts of the solar system.
Nobody knows what causes this effect but there are a growing number of fascinating ideas. For example, I’ve blogged about a Casimir force-like change in inertia. And today, Stephen Adler at the Institute for Advanced Study in Princeton considers the possibility that these spacecraft are banging into lumps of dark matter as they swing past the planet.
In an impressive analysis, Adler doesn’t rule out an interaction with dark matter but he does impose some severe limits on how this process might occur. The problem is that we’ve witnessed both increases and decreases in the acceleration of these spacecraft so any dark matter model would have to allow for this.
http://arxivblog.com/?p=428
Astronomy news on Phys.org
Did you completely missed the recently reported analysis by Slava Turyshev of JPL?
http://www.skyandtelescope.com/news/17846774.html
Zz.
Zz, Turyshev's paper was about the Pioneer Anomaly, not the Flyby Anomalies, which are distinctly different, but which might be related
Garth
Garth
Yes, I know, but I've attended several seminars on this whereby this issue has been brought up together to illustrate the "parameter space" in which any kind of definitive statement about exotic mechanisms responsible for such anomalies need to be tempered down until we know a LOT more.
zZ.
Some exotic explanations have been proposed as the explanation of the flyby anomaly, including the Unruh effect (McCulloch, M.E., "Can the flyby anomalies be explained by a modification of inertia?", submitted 18 Dec 2007 to arxiv.org)
Here, these flybys are modeled using a theory that assumes that inertia is caused by a form of Unruh radiation, modified by a Hubble-scale Casimir effect. ... However, these results were extremely sensitive to the Hubble constant used. As an experimental test of these ideas, it is proposed that metamaterials could be used to bend Unruh radiation around objects, possibly reducing their inertial mass.​
... and dark matter (Adler, S.L., "Can the flyby anomaly be attributed to earth-bound dark matter?", submitted 19 May 2008 to arxiv.org).
We make preliminary estimates to assess whether the recently reported flyby anomaly can be attributed to dark matter interactions. ... We discuss a number of strong constraints on the hypothesis of a dark matter explanation for the flyby anomaly. These require dark matter to be non-self-annihilating, with the dark matter scattering cross section on nucleons much larger, and the dark matter mass much lighter, than usually assumed.​
The answer is probably a lot more mundane: It is probably just sloppy math (Mbelek, J.P., "Special relativity may account for the spacecraft flyby anomalies", submitted 11 Sep 2008 to arxiv.org).
In the following, we show that SR transverse Doppler shift together with the addition of velocities are sufficient to explain the flyby anomalies. Thus, GR does not need to be questioned and the flyby anomaly is merely due to an incomplete analysis using conventional physics.
Oops.
The final paper is very short.
I have read a number of comments on the web asking if the moon's gravity was taken into account with this anomaly. I am sure it was but can no reference to the fact.
Was the moon's influence taken into account?
Related to Can dark matter explain the flyby anomalies?
1. What are flyby anomalies?
Flyby anomalies are unexplained deviations in the trajectory of spacecraft as they pass by planets or other celestial bodies. These anomalies can include unexpected changes in velocity or acceleration, and have been observed in multiple space missions.
2. How can dark matter explain flyby anomalies?
Dark matter is a theoretical type of matter that does not interact with light and thus cannot be observed directly. However, its presence can be inferred from its gravitational effects on visible matter. Some scientists propose that dark matter could be responsible for the observed flyby anomalies, as its gravitational pull could affect the trajectory of spacecraft.
3. Are there other possible explanations for flyby anomalies?
Yes, there are other proposed explanations for flyby anomalies besides dark matter. These include errors in measurement or calculation, as well as the effects of other, currently unknown, types of matter or forces in the universe.
4. Has dark matter been proven to exist?
No, dark matter has not been proven to exist. While its existence is supported by multiple lines of evidence, including the observations of flyby anomalies, it remains a theoretical concept that has yet to be directly observed or detected.
5. Are there ongoing studies or experiments to investigate the connection between dark matter and flyby anomalies?
Yes, there are ongoing studies and experiments to investigate the potential link between dark matter and flyby anomalies. These include further observations of flyby anomalies in space missions, as well as experiments on Earth to try and detect or directly observe dark matter particles.
  • Astronomy and Astrophysics
9K
14K
  • Beyond the Standard Models
  • STEM Academic Advising
