B Can energy be decomposed?
The discussion explores whether energy can be decomposed, specifically in the context of a ball thrown at an angle on a horizontal plane. It establishes that kinetic energy is not fully converted into gravitational potential energy due to the horizontal component of velocity remaining unaffected by gravity. The calculations show that the change in kinetic energy corresponds to the change in gravitational potential energy, leading to a derived formula for height. Participants clarify that while energy itself is a scalar and cannot be broken into vector components, it can be associated with different components of motion. Ultimately, energy is conserved, but its forms can be analyzed through their respective components.
WuliDancer
TL;DR Summary
Force is a vector, so there is synthesis and decomposition of force; velocity is a, so there is synthesis and decomposition of velocity. Energy can be produced by doing work (F·S), and it can also be expressed as velocity (Ek=mV²). So can energy be decomposed?
Let's construct a model: a small ball with mass m is thrown on a horizontal plane with a V, and the direction of the velocity makes an angle θ with the horizontal plane. What is the maximum height it can reach? (ignoring air resistance) We that the kinetic energy of an object will not be completely converted into gravitational potential energy. The velocity in the horizontal direction will not be affected by any acceleration (the of acceleration is external force, and the object is not subjected to force in the horizontal direction when it is flying in the air). Therefore, it will not be converted gravitational potential energy. The amount of velocity in the vertical direction that can be converted into height depends on the velocity at the highest point - obviously 0, so the is completely converted into height.
Let's try:
Initial kinetic energy: E1=½mV²=½mV²sin²θ+½mV²cos²θ
You will find that sin²θ+cos²θ=1 seems to be a coincidence. Let's continue
Final kinetic energy: E2=½mV²cos²θ
Change in kinetic energy: δE=-½mV²sin²θ
The change in kinetic energy is exactly the opposite of change in gravitational potential energy, so
Change in gravitational potential energy: δE=½mV²sin²θ
δE=mgδh
Solution for δh=½V²sin²θ/g
Do you agree with this solution?
:welcome:
Since it doesn't have components, it can not. Energy is a scalar quantity, not a vector: it has a magnitude but no direction.
It is not a coincidence. You could consider it a consequence, though (divide Pythagoras ##a^2+ b^2 = c^2## by ##c^2##) :wink:
Likes Ibix and Orodruin
I think what you did is easier understood by writing the velocity as a vector, ##\vec{v}##. The kinetic energy is then ##\frac 12m\vec{v}\cdot\vec{v}## which you can expand as ##\frac 12m(v_x^2+v_y^2+v_z^2)##.
So you can't break energy down into components in the sense of a vector, but you can write an energy associated with each component of a vector and they will add to the total energy (as long as you work in an orthogonal basis, anyway). Since it's only ##v_z## that's changed by gravity, it's only the ##\frac 12mv_z^2## that changes.
Likes Gavran, Baluncore, jbriggs444 and 1 other person
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
