B Can frame dragging do this?
  • B
  • Thread starter Thread starter Ankit Doshi
Ankit Doshi
I want to share a thought from Gravtiy probe B satellite experiment . Can frame dragging , a rotating object puncture the space time Fabric ? i am not a physicist
just for imagination - If we put a satellite at L1 point ,which has equilibrium in gravity
In this satellite there are 2 sets of rotating spheres . In 1st set there are 2 spheres rotating very near to each other , with optimum RPM and Mass , but rotating in opposite direction to each other . 1st sphere in clockwise 2nd in anti clockwise or other direction .
2nd set of spheres is at few feet distance from the 1st set . 2nd set also has the 2 rotating spheres like 1st one.
if spheres of both sets touch the partner sphere at the exact same time , can it create a small worm hole between them ? when spheres of both sets are rotating and creating frame dragging , and entangling gravity lines , when the spheres touch each other for a second , can they puncture space time fabric ? 1 set of spheres is not enough because worm hole needs 2 ends .
Either above idea is good , or it is total foolish idea , but i just want to put this idea in universe , if anyone finds it interesting.
And everything doesn't have to be created hard way , they also found a easy way to create diamonds by CVD technic without high pressure and temperature.
i know above thought is a foolish idea , but still wanted to share it
Thanks
Ankit Doshi
No.
Likes sophiecentaur, Nugatory and hutchphd
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
