A Can high air velocity in vacuum system create "freezing" of the pipe?
Air can potentially "freeze" in a section of reduced cross-section due to increased velocity, particularly in moist conditions. The key factors influencing this phenomenon are temperature and pressure, both of which decrease as air velocity increases. In high-speed scenarios, such as those in wind tunnels, preheating is necessary to prevent oxygen from liquefying due to significant temperature drops. Additionally, drying the air is crucial to avoid the formation of liquid water or ice crystals. This issue is also relevant in natural gas distribution, where pressure drops can lead to icing problems.
kaigoss69
TL;DR Summary
Hi folks, very simple question, but have not been able to find an answer: Assume a vacuum pump pulls air through a pipe. Also assume that within the pipe run, there is an area with reduced cross section, creating a temporary increase in air velocity. Also assume the air is very moist, and is at room temperature. Question: Does the air in the section where the cross section is reduced have a possibility to "freeze" given a high-enough air velocity? If yes, at what velocity of air would "freezing" occur?
Sure, though you parameters are all wrong. A few things to consider:
  • The system will also be highly compressible so an increase in velocity could require an area increase or decrease depending on the specific conditions.
  • Temperature and pressure are the relevant quantities to determine whether you get any fun non-gases that form. They both decrease when velocity goes up.
  • It's not just water that can get interesting like this. High-speed wind tunnels at Mach 5 or higher have to heat their reservoir air because it expands so much that the temperature gets low enough for oxygen to liquefy. Preheating prevents this from happening, making sure the test gas remains a gas.
  • Given the above, the air must also be dried to avoid liquid water or ice crystals forming in the test region.
In short, it's a very real phenomenon.
Likes Lnewqban and jack action
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
