Can I hardwire 12v light to my 110v house wires?
  • Thread starter Thread starter greggo
    12v Light Wires
Hardwiring 12V LED lights to 110V house wiring requires a transformer to convert the voltage. If the lights need a DC supply, a 110VAC to 12VDC transformer is necessary. It's important to ensure the transformer can handle the current required by the LED lights. Hardwiring can void home fire insurance if not done by a licensed electrician, so using a plug-in transformer is recommended for safety. Proper equipment and caution are essential when modifying electrical systems.
greggo
I have a strand of 12v led lights that I'd like to use as under mount lights for my kitchen cabinets. Is there a way to hook the lights up to my existing 110v wiring assuming there is a converter necessary?
do the LED light units require an AC or DC supply ?
they are available in both versions
if AC, then you would need a 110V to 12V transformer plug pack ( wallwart)
if DC then a 110VAC to 12VDC transformer plug pack ( wallwart)
have you got a link to the type of LED light units you have so we can make a more informed response ?
cheers
Dave
It requires a DC12V input. Before, I used a 9V wall plug, but now I'm wanting to hard wire them. So I guess I need the 110VAC to DC12V transformer?
Yep. Just look for the DC 12V output wall transformer that has a high enough output current rating to supply the needed current to your LED string.
Perfect. Thank you.
I assume you are not a licensed electrician so anything you hard wire into your mains supply will void your home fire insurance. Best to stick with a plug in tranny
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
