Can i use bernoulis inequality like this?
  • Thread starter Thread starter Nerpilis
    Inequality
Nerpilis
can I use bernoulis inequality like this for finding this limit?
\lim_{n\rightarrrow\infty}(1+\frac{1}{2n}) \geq \lim (1+2n(\frac{1}{2n})) \geq 2
Well,first of all, you aren't using Bernoulli's inequality.
Bernoulli's inequality says that
(1+x)^r\ge 1+rx
as long as x and r are both larger than -1.
In this case, r= 1 so Bernoulli's inequality doesn't say anything.
In any case, isn't it obvious that, as x->\infty,
\frac{1}{2n}-> 0?
And so
[frac]1+ \frac{1}{2n}\rightarrow 1[/tex].
Or did you mean
lim_{n\rightarrow\infty}\left(1+\frac{2n}\right)^{2n}?
Yes, Bernoulli's inequality applies to this and shows that the limit is greater than 2. In fact, it should be clear that the limit is e which is certainly larger than 2!
your right i did have a typo i meant
\lim_{n\rightarrrow\infty}(1+\frac{1}{2n})^{2n} \geq \lim (1+2n(\frac{1}{2n})) \geq 2
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
