Can I use VPN at this forum?
  • Thread starter Thread starter user079622
    Security
Using a VPN on this forum is not explicitly prohibited, but its acceptance depends on the specific circumstances and the type of VPN used. Users are encouraged to try accessing the forum with a VPN, and the forum administrators will inform them if there are any issues. While privacy is acknowledged as a right, the forum also reserves the right to block VPNs associated with malicious activities. If users are participating for legitimate purposes, they are likely to have no problems. Ultimately, the forum's policy balances user privacy with the need to maintain a safe environment.
user079622
Is it allowed to use VPN at this forum, or software recognize VPN as spam?
It's not a binary answer, some we may allow, some we may not. Give it a try and either we'll let you know it's a problem or you're good to go. Is there a specific reason you are using a VPN?
VPN is made for privacy..
Why you block VPN account? people have a right to privacy..
Yes, you certainly do have a right to privacy, and this forum has a right to conduct itself however Greg decides it should, including the ability to shut down discussion by anyone who seems to have some nefarious reason for hiding behind a VPN.
If you're just here to learn some science and perhaps contribute some yourself, then as Greg said, just go for it. You should be fine.
Likes Vanadium 50, BillTre, fresh_42 and 1 other person
As @phinds explains, we don't outright block VPNs but if a VPN is known to harbor nefarious activities, we may choose to block those.
Likes russ_watters and phinds
Homework Statement: Not applicable. I'm asking about a technical problem with the PhysicsForums software Relevant Equations: \left(-2+2 \,\mathrm{I}\right)^{\frac{1}{3}} \left(-2+2 \,\mathrm{I}\right)^{\frac{1}{3}} I posted the LaTeX code for an expression in the "relevant equations" and "attempt at a solution" boxes. When I'm in the "attempt at a solution" box and I click "Preview," I do not see a preview of the expression properly displayed, only the code. After I post this message...
