Can I write -5m/s to the right?
  • Thread starter Thread starter abc612008
The discussion centers on the confusion surrounding the expression "-5m/s to the right." While one participant argues that the negative sign contradicts the direction, others clarify that in Cartesian coordinates, "-5m/s" can imply motion to the left if right is defined as positive. The consensus suggests that while writing "-5m/s to the right" is technically incorrect and potentially confusing, it is not entirely invalid. The teacher's explanation that "-5m/s" implies "to the right" is debated, with some asserting that it should indicate motion to the left instead. Overall, clarity in communication is emphasized when discussing directional velocity.
abc612008
Member advised to use the provided formatting template when starting a new thread in a homework forum.
My teacher told me it's wrong to write -5m/s to the right since the negative sign and "to the right" are contrary and therefore don't make sense. However, she said it's okay to write -5m/s because it implies "to the right".
(The correct answer she said is 5m/s to the left)
(Sorry for not using the template because it is irrelvent to specific problem)
It depends.
If the answer is 5m/s to the left then it is clearest to write it that way. But if you are working in Cartesian coordinates you would write ##\dot x=-5m/s##.
So I would say your answer is technically correct but might not be the clearest in the circumstances.
I wouldn't say that "to the right" and the minus sign are contrary; they combine to produce "to the left".
Likes abc612008
If you define right as positive then a velocity of -5m/s implies motion to the left. So either that's a typo or she is wrong?
Stating "-5m/s to the right" is confusing but not invald, its a bit like using a double negative in an English essay.
I guess she meant that if you just say -5m/s without specifying left or right then the default is right positive, so "-5m/s" implies 5m/s to the left.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
