Can interior pressure of a tornado be calculated?
The discussion focuses on calculating the interior pressure of a tornado using centrifugal speed and radius. It suggests that while a simplistic model assumes uniform angular velocity and density, this approach is flawed. The pressure gradient can be derived from the air density and centrifugal acceleration at a specific distance from the tornado's axis. By calculating the centrifugal acceleration at the tornado's rim and integrating the pressure gradient inward, one can estimate the interior pressure. This method provides a theoretical framework for understanding tornado dynamics.
skeptic2
Can the interior pressure of a tornado be calculated from the centrifugal speed of the tornado and its radius (centripetal force)? For example, given a tornado with a 1/2 mile radius and a centrifugal speed of 200 mph, how much would the interior air pressure be?
A simplistic calculation would assume that the air mass is rotating as a unit with a fixed angular velocity and a fixed density. [That's wrong, but it's a start].
You could then get the pressure gradient based on the density of air and the centrifugal acceleration at a given distance from the axis. Add up the pressure gradient along a path working from the outside to the center and you have an answer.
Why don't you begin by calculating the centrifugal acceleration at the rim?
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 21 ·
  • · Replies 22 ·
