Can Movement and Heat Unlock the Secrets of Time Travel?
  • Thread starter Thread starter Bugge
    Heat Movement
The discussion revolves around the concept of movement and its relationship to heat generation. It is clarified that while movement involves the motion of atoms, the heat felt is primarily due to the random motion of molecules, not just the movement of an object as a whole. When running or moving quickly, minimal heat is generated because the overall molecular motion remains largely unchanged. The sensation of warmth from a whip's impact is attributed to energy transfer into the thermal motion of the affected area, alongside a biological response. Understanding these principles helps clarify the nuances of movement and heat in physical interactions.
Bugge
Now, I am very dull, but something that has made me ponder for quite some time is movement and how you define it. As I've understood the movement of the atoms is what can make an object feel cold or warm or maybe even painful, and when you drop an icecube in a cup of water it will cool down because the atoms of the icecube attracts the heat or stops the movement of the surrounding water atoms (Well, maybe not exactly, but I am not very sure how to explain it, and even less sure if I am right). Is this somewhat partially correct? If it is, how come when you run or move something very fast, that very little heat is generated? I mean, since movement is the same as atoms being moved around, should the heat generated not be much more noticeable?
Also, I posted a topic long ago about timetravel, and I just checked it. I have been unable to answer it until recently - all thanks to our excellent ISP. I'd like to say thank you for your answers, and there was some pretty interesting links. Way over my head, but the little pieces I understood so far has been very helpful.
Thanks in advance :-)
Bugge
Science news on Phys.org
'Heat' is the random motion of molecules. An object sits motionless on a table, yet its molecules are in constant motion. If you increase its temperature, the random motion becomes faster.
But just moving something as a whole does not affect the random motion of its molecules.
Thank you for the simple answer :-) But if you get a whip over your fingers, for instance, it will feel warm (And quite painful aswell) for quite some time. Is this affecting the random movement of the molecules then, or is it just a "response" from your body?
What do you mean?
Assuming that you mean your fingers are hit by a whip, then some of the energy of the whip will end up going into random thermal motion of your fingers. But what you feel is mainly a biological response.
Exactly what I meant. Sorry, I keep mixing Danish and English together. Thanks for the answer :-)
Bugge
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
