Can nitrous oxide be made from air?
  • Thread starter Stormer
  • Tags
    Air
In summary, it is possible to produce N2O from readily available fluids such as air and water, but the most efficient way currently known is through intermediate steps involving the Haber-Bosch process. There is no known more efficient method at this time.
Stormer
117
The air is full of nitrogen and oxygen but can this somehow be reacted together to make N2O without any other chemicals involved (other than as a catalyst or other non consumable role)?
Chemistry news on Phys.org
Lightning?
Likes Astronuc and TeethWhitener
What has your research told you about how N2O is produced, whether naturally or artificially? Did you find any that do not involve intermediate steps?
Likes Astronuc, bigfooted, jim mcnamara and 2 others
Why would one want to do that?
https://cfpub.epa.gov/si/si_public_record_report.cfm?Lab=NRMRL&dirEntryId=129929
Stormer said:
Does that not mostly just make ozone?
The origin of nitrous oxide in the atmosphere is due to the reaction between nitrogen molecules and oxygen atoms formed by the photochemical dissociation of ozone in the atmosphere.
https://journals.aps.org/pr/abstract/10.1103/PhysRev.95.320 (received: 1954; published: 1955)
Stormer said:
Do you really think that is a good answer to my question?
Seems like a good answer. A link is provided for one's edification.
The triple bond between the two nitrogen atoms in N2 is the second strongest covalent bond there is. The C-O bond in carbon monoxide is slightly stronger.
Nitrogen is a very stable compound. Around about the end of the 19th century, there was concern that, by the 1920s, widespread starvation would break out.
The problem was that there was not enough nitrogen-containing fertilizers to grow enough wheat to feed the increasing world population. What was needed was a catalyst that would speed up
N2 + 3H2 ----> 2NH3 (ammonia) Once you have NH3, it's easy to make fertilizers (or explosives)
Today about 50% of the nitrogen atoms in our bodies come from this reaction.
There is a wonderful book on all this
https://www.amazon.com/dp/0307351793/?tag=pfamazon01-20
Likes berkeman
Diesel engine fixes atmospheric nitrogen - unfortunately.
Not much.
The "best" route i found that does not involve other chemicals than those that is readily available everywhere (water and air) is to first elektrolyse water to hydrogen, then make ammonia with the haber bosch process, and then make the N2O by oxidation of the ammonia.
But this route is really inefficient and complex.
That is why i am asking here obviously.
To make N2O without having to get other chemicals to do it. For example to make it just using energy and the resources available offshore on a boat.
So is there a way to do this efficiently and to separate out the N2O with a machine?
I am obviously not asking for N2O as a trace gas byproduct of another process. I am asking about how you can produce N2O from fluids that is readily available everywhere (like air and water). So no that is not a good answer at all.
That's a bit shifting the goal post. You asked whether it is doable - yes, it is. mjc123 signaled the most obvious natural way in the first post, you listed one in your own post. Now you are asking a different question, one about the process economy. My bet is that no, there are no known more efficient ways than the one you listed, otherwise they would long replace the Haber-Bosh process and its variants (once you have any nitrogen oxide converting it into other nitrogen compounds is relatively simple, it is the initial reaction involving breaking of the triple bond that is the difficult step).
Likes Bystander
FAQ: Can nitrous oxide be made from air?
Yes, nitrous oxide (N2O) can be made from air through a process called the Ostwald process. This involves the oxidation of ammonia (NH3) to nitric oxide (NO), which is then further oxidized to N2O.
What is the composition of air?
Air is primarily made up of nitrogen (78%), oxygen (21%), and trace amounts of other gases such as argon, carbon dioxide, and water vapor. Nitrous oxide is not naturally present in air, but can be produced through industrial processes.
Is nitrous oxide a greenhouse gas?
Yes, nitrous oxide is a potent greenhouse gas that contributes to global warming. It has a global warming potential 298 times greater than carbon dioxide over a 100-year time horizon.
What are the uses of nitrous oxide?
Nitrous oxide has several uses, including as an anesthetic in medical procedures, a propellant in aerosol cans, and a performance-enhancing gas in race cars. It is also used in food production and as a recreational drug.
How is nitrous oxide harmful to the environment?
In addition to its contribution to global warming, nitrous oxide can also deplete the ozone layer and contribute to acid rain. It can also have negative effects on human health, such as damaging the respiratory system and causing headaches and dizziness.
