MHB Can Odd Positive Integers Solve the Equation $\cos kx = 2^{k-1} \cos x$?
The discussion focuses on solving the equation $\cos kx = 2^{k-1} \cos x$ for odd positive integers k. Participants express appreciation for a calculus method proposed by lfdahl, noting its effectiveness in simplifying the problem. There is acknowledgment of a misunderstanding regarding the inequality's validity, which is corrected to apply beyond just k=1. The conversation highlights the collaborative nature of problem-solving in mathematical discussions. Overall, the thread emphasizes finding efficient methods for tackling complex equations.
anemone
MHB
POTW Director
Let $k$ be an odd positive integer. Solve the equation $\cos kx=2^{k-1} \cos x$.
Mathematics news on Phys.org
\[k = 1: x\in \mathbb{R}\\\\ k = 3: cos(3x)=4cos(x) \Rightarrow cos^3(x)-3cos(x)sin^2(x)=4cos(x)\\\\\Rightarrow cos^3(x)=\frac{7}{4}cos(x) \\\]
- which only has the trivial solution: $cos(x)=0,\;\; i.e. \;\;x =\frac{\pi }{2}+p\pi,\;\;p\in \mathbb{Z}$
\[k = 5,7,9 ...: cos(kx)=2^{k-3}cos(3x)=2^{k-3}4cos(x)\]
So I end up with the same solution as for $k =3$.
I guess there are other (better) ways to solve the equation. Maybe one could use the inequality:
\[\left | \frac{cos(kx)}{kcos(x)} \right |\leq 1\]
- to show that the only non-trivial solution ($cos(x)\neq 0$) appears for $k=1$
Another way could be to define the function:
\[f(x)=cos(kx)-2^{k-1}cos(x), \;\; k = 3,5,7 ...\]
I would look at the set: $S = \left \{ x\in\mathbb{R}|f(x)=0 \right \}$
Now, $f'(x)=-ksin(kx)+2^{k-1}sin(x)$ so there is at least one inflection point between $0$ and $\pi$
But $f''(x)=-k^2cos(kx)+2^{k-1}cos(x)=(1-k^2)cos(kx)$ for $x\in S$
$f’’(x)=0$ is only possible if $k = 1$ or $x=\frac{\pi}{2}\in S$ and due to periodicity $S = \left \{x|x=\frac{\pi}{2}+p\pi, p\in\mathbb{Z} \right \}$
Thankyou for any corrections to the above considerations!
Your answer is correct, well done, lfdahl!
The calculus method that you showed is great, I think, because I don't really go through them, (I have a little headache today:o)...but your proposed method suggests an easier way to approach the problem as I see if:
$\left| \frac{cos(kx)}{kcos(x)} \right|\le 1$ we have $\left| kcos(x) \right|\ge \left| cos(kx) \right|$ but since $\cos kx =2^{k-1} \cos x$ and $k>0$, we get
$k \left| cos(x) \right|\ge 2^{k-1}\left| \cos x \right|$
This is like asking what $k$ will it hold so that $k \ge 2^{k-1}$ and obviously that inequality is true iff $k=1$.
And the result follows where we have $x=\frac{\pi}{2}+p\pi, p\in\mathbb{Z} $.
I see 2 cases
1) k = 1 for which is it is identity
or 2) cos kx =0 and cos x =0 or which $x=\frac{\pi}{2}+p\pi, p\in\mathbb{Z} $
kaliprasad said:
I see 2 cases
Oh My...yes, you are right and thanks for correcting my silly conclusion to say that the inequality is true only when $k=1$. I appreciate it!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
