I Can Placing Earth Between 3 Black Holes Slow Down Time?
Joe Bond
I am just wondering if placing the Earth equidistant from 3 black holes that are spinnng would slow down time on the Earth, due to the time dilation effect. Would that give us more time to live?
Why do you need three? Being in orbit around one would do. And it only slows down the passage of time relative to observers far away from the black hole. For the inhabitants of Earth time would seem to pass normally. Nobody would have gained any extra time to watch Netflix before they died.
Likes berkeman, Dale and Joe Bond
Assuming of course we aren't past the event horizon yet we are relatively close
oh I see, that's sad. Thank you for your reply
Time dilation isn't something that you directly experience. Instead, the special and general theories of relativity entail something called differential ageing. This means that if you go and spend some time close to a black hole and then return, you may well be significant younger than someone who stayed at home. The reason for this is that you have taken a shorter path through spacetime. The length of your path through spacetime is precisely the amount of proper time that has elapsed for you. Proper time is what you experience.
So, although when you return you may be younger than the friends you left behind, you have literally experienced less time. In that sense you can't directly get the best of both worlds by ageing less yet experiencing the same amount of time to enjoy life. You need herbal remedies for that!
Likes cianfa72 and Joe Bond
thank you for your reply
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
