Can Polynomials be Factored if Numerical Approximations to Roots are Used?
The discussion centers on factoring the polynomial x^5 - 1, with the known factor (x - 1) leading to (x - 1)(x^4 + x^3 + x^2 + x + 1). Participants suggest using the roots of unity for a more efficient factorization, noting that the quartic can be broken down into two irreducible quadratics. There is a debate over the necessity of exact roots versus numerical approximations for the assignment, with a consensus that exact solutions are preferred for formal factorization. The conversation highlights the importance of understanding the context of the assignment to determine the appropriate method for factorization. Ultimately, the need for exact roots is emphasized in academic settings, especially when dealing with polynomials.
spongegar
I need to factor x5 - 1.I know (x-1) is a factor and have gotten:
(x-1)(x4+x3+x2+x +1)
I'm not sure where to go from here.
Thanks in Advance.
So what you're looking for is to solve x^5-1=0
A better approach to solving this is to convert 1 into its mod-arg form.
So we have x^5=1 and 1=cis(2\pi) or e^{2i\pi} if you're more accustomed to that. Now can you find the roots of unity?
Yes, I know that is a much more convenient approach and have used that to find the roots, but I need to factorize it for my assignment.
Thanks.
Thanks.
Finding the roots of unity is a very handy method of factorizing that quartic x^4+x^3+x^2+x+1 into two irreducible quadratics.
Notice that (x-\alpha)(x-\bar{\alpha})=x^2-(\alpha+\bar{\alpha})x+\alpha\bar{\alpha}
where \alpha is a complex root and \bar{\alpha} is the conjugate root. If you let \alpha=cis\theta then you can show that \alpha+\bar{\alpha} and \alpha\bar{\alpha} are both real values.
A complex number a is a root of the polynomial P(x) if and only (x-a) is a factor of P(x). If you find all of the roots (which are just the 5th roots of unity), then you automatically get the factorization as well.
Thanks in Advance.
If you are just wanting to factorize that quartic, you can input the coefficients here to see the solutions.
There is a much better way of finding the roots than using that site which merely gives you numerical approximations.
Numerical approximations may be all that OP needs. He hasn't indicated.
Yes he has
Mentallic said:
Yes he has
The roots will give him the factors. 10 sig figs may be sufficient for OP's needs. He hasn't indicated.
The fifth roots of 1 are ak=exp(2pi/5*k). Following Mentallic's suggestion, the second-order factors are
x^2-2xcos(72°)+1 and x^2 - 2 xcos(144°)-1.
It can be derived from the regular pentagon that
\cos(72°)=\frac{\sqrt5-1}{4}
and \cos(144°)=-\frac{\sqrt5+1}{4}.
With these, the exact expression of the factors are obtained.
ehild
He may not have specifically said "I need to find the roots in exact form to factorize x5-1" but when you factor something, you don't do it with numerical approximations, you do it with exact roots - especially when the roots are relatively easy to find and it's a common question to be asked when studying complex numbers.
I've seen numerical approximations to equations, but never have I seen them taken a step further and put into a factorized form.
For example, I wouldn't be satisfied with x^2-2\approx(x-1.414)(x+1.414) when (x-\sqrt{2})(x+\sqrt{2}) is readily available. And I've never seen numerical roots being applied in such a fashion either, but it might be used like that in some cases I guess.
That's right, he didn't.
If the numerical approximations are all that's needed, then they may well suffice.
I think you might be satisfied with the 1.414 approximation, sometimes.
OP indicated he needed "to factorize it for my assignment". Sure, that task may constitute the assignment, in which case the exact solution would be required. But maybe his assignment was a curve-sketching task with no marks for the exact solution, or the factorizing was incidental to a physics assignment where the numerical approximation would be what was used anyway. Only the OP can know, and he's not saying. I didn't seek to restrict his options to exact solutions only.
In any case, ready access to approximations affords an easy way for him to check his exact solution.
If you can show me one example of where numerical approximations to roots of polynomials have been put in factored form, then you have a case. Until then, it just looks to me as though you're desperately grabbing at straws to try back up what you initially said.
I'm not here to point the finger and laugh at your honest mistake, I'm only trying to set the facts straight that if an assignment asks for a polynomial to be factored, then it must be in exact form. If it asked for the solutions however, then they may be numerical approximations.
I made no mistake. You assumed he needed exact solutions, and that's fair enough. But I made no such assumption. OP's wording had a nuance that hinted his need may be part of an assignment, not the totality of it. Were this to be a case where he'd end up using the numerical values anyway, he may not even need to spend time evaluating the exact factors. I pointed out his options were open; OP can make the judgement on what suits his need.
