Can pressure differential close lateral window?
In summary, the article discusses the concept of pressure differential and its potential to close lateral windows in various contexts, such as in engineering or architecture. It examines the mechanics behind pressure differentials, the conditions required for effective closure, and the implications for design and safety in structures. The analysis highlights both the benefits and limitations of using pressure differentials for this purpose, emphasizing the need for careful consideration in practical applications.
mantisshrimp23
I'm trying to think of the least creepy reason I found my small lateral bathroom window closed this morning. I live in a 2 bed/1 bath apartment on the ground level with my two dogs and no one else. I rarely have people over. My bathroom doesn't have a fan and I don't have the best memory, so I typically leave my small bathroom window open about two inches year-round. I do this even in our 110 degree heat when I have the AC set to 72 (please don't judge). Is there any possibility that some form of a pressure differential occurred to cause my lateral window to close on it's own? (I know this is a long shot, but I am a woman living alone so I'm trying to think of every possibility other than the most likely one of it being closed by another human).
Note: I do have a dog door to my small patio that I easily fit through. I have just upgraded my ring program so hopefully I can record from my living room camera (which you would have to pass by to get to the bathroom). I am very conscientious about locking my front door every morning when I go to the gym and work. And this is kicking me back into the habit of setting my alarm system.
How big is this window?
Which way does it open? (what does 'lateral' mean?)
How much friction is there to close it?
Conceptually, it would be very difficult for a pressure differential inside the house to draw a window closed. A breeze or wind outside the house might plausibly do so.
You say you live at ground level. Is the window reachable from outside? Maybe some passerby just knocked it closed.
Likes russ_watters
Don't google "lateral window". Not only you will have no idea what OP means, but the results are kinda bloody.
(yes, I know, now everyone will try)
And I hollered "Don't look Ethel!"
But it was too late. She'd already Googled...
(Boogity boogity)
Welcome, @mantisshrimp23 !
It is very unlikely that an occurrence of some form of a pressure differential in a small apartment can cause enough airflow coming in through the window as to close it.
Please, consider other causes, like gravity combined with age of window closing mechanism, strong vibrations or wind gusts from an exterior source, or a rubber ball colliding with and closing the thing.
I'm guessing it's a window that slides horizontally rather than vertically.
Do the dogs ever get up and look out that window? Maybe one of them was pushing around with their nose and managed to close the window.
It's a good idea to cut a wooden dowel to the proper length to prevent the window from being opened any more than that 2".
Dog doors typically come with a metal cover plate that you can insert when you want to be sure the door stays closed. Do you have that attachment for your dog door?
Likes Lnewqban
Maybe. I'm guessing a window that is hinged on the left or right side.
But guesses are a sure path to tears and heartbreak.
I assume lateral window mean sliding open horizontally. That's very common. I have those in 3 of the houses I lived in. Never once I have that opened on me without me knowing it.
I don't want to get into physics, My advice for your safety is put a SLIDING WINDOW LOCK, which I put in all the windows that I plan to open for air. If you go on Amazon and type this in, you will see it.
It's dangerous for single woman living on ground floor to NOT lock the window. I even put iron bars and iron gates when possible.
Watch out the dog opening.
Back to mysteriousness, Depends on how old you are, Me and my wife are pass 70. Believe me, we starting to notice lights left on over night that we swear we turned off and double check!!!.🤣 🤣 🤣 🤣 🤣 🤣 🤣 🤣 🤣 🤣 🤣 🤣
Likes Nik_2213
Are there temperature fluctuations which might cause a sliding window to 'inch-worm' ?
Or a side-hinged 'escape' window to wriggle ??
IMHO, if panel is hinged, may simply be the wind.
FWIW, I've seen one of latter swing shut when a house-door was opened, a wind-gust's pressure wave providing enough 'differential' to drive very recently lubricated / de-gunged double pivots.
Same gust also slammed wash-room's door. Fortunately, I'd fitted several chunky 'foam horse-shoe' child finger protectors to door edge to prevent cats being trapped...
